Question about Kyocera Office Equipment & Supplies
Kyocera scans enlarged copies - Kyocera Office Equipment & Supplies
2 Suggested Answers
SOURCE: How to enlarge a picture that is scanned or
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Posted on Aug 07, 2010
Kyocera Taskalfa 552ci will not copy single sided. 0800 Jam but will so may other functions...
the service manual says to replace the main pcb before you do this try to upgrade firmware even if it is current or try a different ADF the DIMM could be the problem if the board has 1 try cleaning the contacts with an eraser welcome to Kyocera repair
Mar 07, 2017 | Kyocera Office Equipment & Supplies
How do I fix Kyocera fs-1118mfp which outputs only partial copy of any document. When making a copy only part is copied. Placed the original on glass.
check to see if all the lights are turning on as it tries to scan (do a scan with the lid up and nothing on the glass.
Possiby need to rplace the drum in the printer.
Sep 01, 2016 | Kyocera FS-1118MFP Laser Printer
How do i enlarge a scanned photo
Your printer software should have an enlargement feature. If not, print he photo then copy it using enlargement feature.
Feb 13, 2015 | HP PhotoSmart Office Equipment & Supplies
My kyocera 6025 no image and also black copy
sounds like the scanner is still locked so it dosnt scan the image giving u blank copies or black copies
Feb 17, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Printing an enlarged version of a scanned photo
The best way is to use software like Corel PhotoPaint and RESAMPLE the pix to the sze you want. YOu typically will get better resolution.
You could also try selecting the "Fit To Page" setting of the printer window before you tell it to print.
Sep 14, 2009 | HP Photosmart C6280 Printer
KYOCERA CS 1820COPIER/FAX
I don't work on that particluar product line so I can only comment on what zoom feature can do to copies in general
It could be that the zoom is too high to fit on 8/12 x 11 paper you may have to reduce it to get it to fit.
Otherwise you might want to check with a Kyocera tech.
Jun 12, 2008 | Kyocera Copystar CS-1820 Black and White...
18 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
