Question about JVC TH-A35 System
Reset TH-A35 System
How the reset system?
When the sound go up it shut down completeley
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition specially when the volume is high . This can be also due to LOW VOLTAGE/LOW CURRENT to the amplifier and so when the need is insufficient it can shutt down. So use a voltage stabiliser is mains voltage is low
Also check the speakers resisitance after disconnecting the speakers
Thank you for using Fixya
Sep 01, 2011 | JVC TH-A35 System
The DVD player seems to immediately attempt DVD mode upon powering on, despite no disc being present. The display shows "ERROR, PRESS POWER OFF/ON TO RESTART" and no other action is possible...
You have an internal mechanical switch/sensor which failed and will need replacement.The reason it is giving this message because the sensor might have been stuck in a position when it was damaged. And also along with it some parts(semiconductors and capacitors needs to replaced too)need some checking too.
Jan 30, 2011 | JVC TH-A35 System
I used to use my TH A35 via scart to tv ext 1, when i moved i had a virgin media box installed and because i hadn't unpacked by TH A35 the guy used ext1 scart on my tv and tuned in all the programmes to...
Welcome to FixYa
Dear User
This Guide can Help you to Configure your Device Properly. Click here to Read/Download the Guide[You should need Acrobat Reader to View this Guide-You may Download from Here ]
Thanks for Connecting FixYa
Aug 30, 2010 | JVC TH-A35 System
Radio Tuner problems
Backup memory battery may be the cause.
Mar 27, 2017 | JVC TH-A35 System
No surround through S/PDIF
The problem is that your system does not support surround via S/PDIF. It detects it as a regular stereo jack. You could always add a digital out to your PC such as Optical or Coax Digital.
Feb 04, 2008 | JVC TH-A35 System
Subwoofer jack not working
Try using another cable. Such as a spare Component cable. As a general rule if the cable is large in diameter it will do the job. You dont have to buy a Woofer cable specifically, as stated above a Component cable will be more than enough.
Jan 02, 2008 | JVC TH-A35 System
Unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
Nov 25, 2007 | JVC TH-A35 System
TH-A35 receiver
You can't get 5.1 sound from a MP3 source !!! You get a 5.1 sound only from a good STEREO (analog) source or from a REAL 5.1 DVD audio track. Also check your "Autosurrond" setting on the remote-control.
Sep 14, 2007 | JVC TH-A35 System
Error message upon powering on
Unplug it for 10 seconds then plug it in again
Apr 23, 2007 | JVC TH-A35 System
JVC TH-A35 System Logo
118 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
