Question about Kenmore Elite 45986 Front Load Washer
Machine stopped in the middle of a washing cycle. It would not drain nor would the door open. I was able to get the door open and i checked the pump and found a nickle in it. I cleared the nickle and put the pump back on. The original problem was that the door would not open. But now the lever is still stuck in the closed position and now I cannot get the door to close. Is there a reset for the door switch?
  • 5911 Answers
SOURCE: Kenmore Washing Machine Model 110.20862990
You don't open the rear panel. This is a typical symptom of a lid switch problem. The link below will explain how to access it. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (Part number 3949238). For instructions on how to replace a lid switch, click on the following link:
I hope this helps you. If you have questions, please let me know.
Posted on Aug 07, 2008
  • 5911 Answers
SOURCE: Not switching from rinse to drain cycle
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at Select "Search by Part Number" and enter the following part numbers: The lid switch is part #3949238 and the lid strike is part #350733. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Posted on Oct 08, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 4090 Answers
SOURCE: Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Posted on Aug 01, 2009
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Posted on Jul 13, 2010
Ge washing machine/stopped in the middle of the drain cycle
sounds like your pump has got jammed with a coin or usually hair grip.
Sep 18, 2016 | GE Washing Machines
Washer machine shows "ND" and doesnt got in to spin cycles or drain water out
The most likely cause for your issue is excess debris in the pump strainer, or a bad impeller on the pump. If you have a front small trap door on the front left or right, follow the instructions in your manual for cleaning out the trap. If the trap is empty, or does not exist on the exterior, you may need an experienced repair man to open the machine up to get to the pump strainer and check the drain pump. Pleazer Appliance...
Apr 17, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 30, 2013 | Beko Washing Machines
My washing machine is stopping in the middle of its cycle the door locks and the light blinks I tried cleaning out the pump and it started working and then it stopped again
check for drain pipe blockages ours was stopping, i put hose out window and it worked fine so I cleaned out the drain and all ok now.
May 16, 2013 | Washing Machines
When i turn the dishwasher on it start but when it whant's to wash the two red lights goes on and machine beep and stop washing.
After the intital cycle of the water inlet vavle opening the program shifts to the next mode But since there is errors on the controller the machine shuts off with an alarm.
Now check the front door opening switches, check the washer pumps, check the drain cycle/pump.
remove and check the door switch contacts, the pump and the drain.
Jun 14, 2011 | Dishwashers
My 3 year old front loader suddenly stopped draining, spinning, and now the door will not unlock. It still has power and you can hear clicking, it does cycle through wash, but stops at drain and lights...
This looks like the pump is blocked or drain or the pump has gone. to try and solve it best thing to do is open pump filter usually on bottom front of machine to access pump water will come out so be ready. when you have opened the filter you can check for a blockage and give it a clean put filter back on and put it on a cycle and see if it drains. to make door open start a cycle stop it after a few seconds of being on and turn off machine on machine not at plug and leave it for a while it should open. if it does not then switch off for 5 mins and back on and repeat it hope this helps.
Sep 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirlpool frontload washing machine door will not open after the
if there is still water in the washer you can use a wet dry shop vac and attach it to the end of the drain hose.Once all the water is removed from the washer you should be able to open the door.
then you need to check the drain pump for anything that may be obstructing the pump. make sure to check the hose that leads from the bottom of the tub to the drain pump.
Jun 21, 2010 | Washing Machines
The washer stops in the middle of cycle and water stays inside
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
 Brian Main
Brian Main
