Question about Bosch 24 in. SHU43 Built-in Dishwasher
Stuck in rinse cycle
After the washing cycle has finished the machine continues rinsing forever.  This happens only with the 60-70 degree cycle.
  • Anonymous Dec 03, 2007
    the unit ran while a large frying pan apparently blocked the top spray arm from moving. was not at home at the time and noticed that the machine was still rinsing after several hours upon return home. NOW, the problem is that the machine has to be turned off manually by opening the door!!!
    It no longer shuts off after completing the cycle? any ideas as to the problem and or possibly resetting this machine if that is the problem.
  • 130 Answers
Mimmi, If the water isn't reaching temp this will happen. It sounds like a heating issue.
The spray arm being blocked will not cause this. Again your machine isn't heating the water to temp.
Posted on Jan 06, 2008
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
My eurolux dw2112p/1 gets stuck halfway in rince cycle
replace the timer: a tiny gear that is driven by the timer mpotor has broken teeth at that time point
Feb 04, 2013 | Washing Machines
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Matayg Atlantis Washing Machine gets stuck in the Rinse Cycle and will continue to rinse for hours.
This is the sign of a bad timer. It is not sensing how long it has been in the cycle. The timer is not advancing. Replace the timer.
Feb 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Front Loading Washing Machine - stuck in cycle.
there may be a simple solution. on rinse the water level is higher. it is just possible that the water is syphoning out. try putting the drain hose higher in a swan neck
Apr 05, 2007 | Frigidaire GLTF530DS Front Load Washer
My machine was stuck on rinse cycle now on ventilate...
Try first to continue filling up the water resovoir (UP TO FOUR times) to see if the machine completes the rinse cycle on its own. If that doesn't work contact Gaggia Customer Service in the US at 888-389-4123. Sally there was VERY helpful and should be able to resolve your problem.
Dec 31, 2006 | Gaggia Titanium Espresso Machine
Bosch 24 in. SHU43 Built-in Dishwasher Logo
264 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
