Question about Samsung Audio Players & Recorders
Volume turns down by itself until it says VOLMIN
The unit turns the volume down by itself, until the front panel says VOLMIN, as if the turn volume down button is physically pressed. This is permanent, I cannot use the unit because the volume is always turning down. It's constantly beeping while doing this. The unit is a HT-D6730W/ZA.
  • Vince
    Vince Nov 25, 2015
    I actually contacted Samsung directly through online chat and they had no explanation as to why this is happening. I noticed however that the particular model that has this issue (in my case HW-F450) has been discontinued.
    New Friend:
  • 4 Answers
I have a Samsung home theater system model HT-D6730W. I have had some issues with the volume turning itself down till it says volmin. I've seen that I'm not the only one with this issue!!!! I have tried all the suggestions that were posted. Doing a hard reset, changing settings, I bought a cooling pad for laptops Hopi g those would fix it. I called Samsung support Which was a joke!!! I took the putter cover off and cleaned all the dust from the unit, removed batteries from remote, removed all cable connection on the back of the unit other than the HDMI cable going to the tv. Having done all that the unit was still turning its self down. I'm a bit of a tinker and so while the cover was off of the unit, displaying all the delicate stuff inside, I turned on the home theater system and played a movie set the volume to a good listening sound. When it started to turn it self down I remove the wide wire ribbon from the main circuit board going to the touch panel on the front of the unit. Voila!!! Sound quit going down!!!! I unplugged unit and removed front touch panel and cleaned all dust from the inside of it. Put it all back together. Tested. Still doing it. Removed the touch panel again and this time I disconnected the small wire ribbon for the volume touch buttons. Reassembled and tested. NO MORE ISSUES!!! Everything on the front still works other than the volume buttons. You can still change the volume using the remote!!!! I hope this finds everybody that is having this issue with there unit.
Posted on Aug 25, 2016
  • 4 more comments
  • Graham
    Graham Sep 14, 2016
    Thanks for that. I had the same issue except that the volume would go to MAXVOL. I was about throw the whole thing out when I saw your solution. I unplugged the power; unscrewed the cover and lifted it off; popped the front panel off (after disconnecting the wide connecting strip): pulled out the small strip connecting to the front volume buttons and reassembled (don't forget to reattach the wide strip). So far so good. Again, many thanks :o)
  • Kerian Robinson
    Kerian Robinson Oct 24, 2016
    Saved me too thanks Bill!
  • Drew
    Drew Apr 15, 2017
    Thank you so much for your post. I have the same problem with my Samsung HT-E6750W. I tried various things, even locating a small cooling fan underneath the volume control. This seemed to work for a few days until it didn't. Finally I bit the bullet, having not much to lose and disconnected the onboard volume connection on the inside of the front panel just as you said. So far (early days yet) things look good - even without the cooling fan. I am amazed at the number of posts all over the internet relating to fading volume on Samsung electronics, including HTS's, DVD players and even their TV's. I would advise people not buy shares in Samsung - they seem to be blighted AND unhelpful. Goodbye Samsung.
  • Daniel Flare
    Daniel Flare Jul 30, 2017
    Thank you Bill. It helped for me too. Saved me some money getting a replacement.
  • Steve Hallworth-Cook
    Steve Hallworth-Cook Oct 11, 2017
    I have a HW-J8500 soundbar that reduces to MINVOL when swithed on. I followed your info and disconnected the ribbon going to the top panel switches and it now works great. We dont need the switches as everything is controlled remotely. Thanks for the info!!
    New Friend:
The quick fix is to unscrew the cover and also remove the faceplate. There is a very small brown ribbon connecting to a slot where It is labeled in small lettering "vol + / vol -". That ribbon will disconnect the front volume touch panel. That has solved my issue. I own the Samsung Home theatre with the vacuum tubes.
Posted on Dec 10, 2017
    Dedicated:
    Visited the website for 20 consecutive days.
  • 817 Answers
Could it be your remote that is the problem? Take the batteries out and see if it stops happening. If it does then your remote is faulty.
Posted on Nov 25, 2015
Monster80
  • 463 Answers
SOURCE: Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
Posted on Apr 02, 2009
SOURCE: TECHNICS SC-CH550 STEREO SYSTEM
Hi
I belive that you have a lot of dust how is gatherd behind the system in the amplifier and it is preventing it to cool down you need to blow it clean and make sure that you keep the system gets cool air
if the temp in the amplifier gets to high it shut down the system instand of burning it very clever solution from the manufacturer
you have a very good system good luck
Posted on Mar 15, 2009
SOURCE: RCA RT2770 receiver won't turn on
it is a high power switch to get it fixed it will cost about 100 $
Posted on Oct 20, 2008
SOURCE: When volume button is pressed it does not stop going up or down
You can also use the cancel button on the SC-BT100 remote to keep the sound volume from accellerating up or down if you don't want to take the time to unplug for the 5 minutes, if your watching something and don't want to miss it.
Posted on May 19, 2009
  • 56 Answers
SOURCE: samsung ht-q80 won't open tray
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
Posted on Jul 02, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Display on the sound bar keeps going to volmin. it turns down by itself
Is there any settings that allow the unit to reduce the sound at all? Check carefully to see if there are. If you can't find any then there is a fault in the volume control circuit. Volume controls these days are controlled by a chip (IC). These can go faulty.
Oct 21, 2015 | Audio Players & Recorders
Phone turned off itself and i turned it back on, it now says "try again in 538472 minutes"
Do a Full Reset THIS WILL DELETE EVERYTHING!!!!!!!
  1. Press and hold the Volume down and Power buttons at the same time until you feel a vibration (about 10-15 seconds).
  2. When you feel the vibration, immediately press and hold the Volume down button until you see a large exclamation mark.
  3. Once the exclamation mark appears, press the following four buttons in this order: Volume up , Volume down , Power , Volume down . Your phone should now reset and restart itself. (It might take a while for the reset to finish.)
Try again in 134600 minutes
Settings personalization
Jul 10, 2015 | Nokia Lumia 530 DUAL SIM Dark Gray Factory...
Having a problem in turning down the volume both on the unit itself & the remote, can increase the volume both ways but have to wait 15 plus before the remote will turn down the volume. The control on...
The volume control in this unit is most likely an Encoder and these have a nasty habit of getting dirty inside and false reading back to the computer that runs the receiver. In the past , I've had good results opening up the units and spraying what's called De-Oxit D5 into that volume control and rotating the thing a couple dozen times. . De-Oxit can be found on Amazon or Radio Shack
May 26, 2014 | Marantz SR4001
Volume, device inpute issues
Try new battery's in the remote, and check all volume buttons, one may be stuck down.
Mar 23, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Volume decreases during use
Very simple. It is not a defective unit. Simply a matter of volume attenuation, hold the "function" and "grove"keys for aprox 5 seconds until a message saying vac off appears. Problem solved. Resets itself eveytime the unit is turned off .
enjoy!!!
Nov 16, 2013 | Sony RDH-GTK1i Hi-Fi Music System
Volume
This sounds like a case of a dirty/defective rotary encoder. The volume control used here is not the conventional potentiometer type , but a rotary set of switches that tell the sytem if the knob is being turned left ot right.
Do you think you'd be able to open the unit and spray some contact cleaner into the rotary encoder? It might involve dis-assembling it down to front bezel removal.
jango.
Aug 18, 2007 | RCA RS2044 Shelf System
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
3,485 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
