Question about Schwinn Original Airdyne
Shcwinn airdyne making a loud popping sound - Schwinn Original Airdyne
Took a right turn, made a loud pop sound, now won't stop making a popping sound. Not as loud as the first pop sound. What could it be?
Not enough information to answer. Need manufacturer, year, model, and engine size in order to answer the question.
Oct 22, 2015 | Cars & Trucks
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
Pedal / Chain shaft(?) problem
Sounds like you will need new bearings,check manufactures website for parts and instructions.shouldnt be a hard fix.
Nov 29, 2013 | Schwinn Airdyne Evo Comp Upright Bike
The hatch wont stay up, makes a loud popping sound and comes down.
sound like the shocks that hold the hatch open have been over extended, thats what the popping sound is when its opened.. replace the shocks and that will keep the hatch open and eliminate the popping sound,
Nov 06, 2012 | 2010 Chevrolet Chevrolet Traverse LT
My airdyne is locked up and won't move. it is not the locking knob. it is an older airdyne.
Take it in for service, it more that likely needs a new bottom bracket rebuild or kit. You have to have the right tools to replace or rebuild. Make sure that your chainguard is not stopping the chain from moving.
Jan 18, 2011 | Schwinn Original Airdyne
Makes an loud clicking/popping sound
The audio outputs are intermittently shorting to their supply and allowing DC voltage to pass - the speakers will be damaged if it continues. you can confirm this by measuring (with a dc voltmeter)at the speaker outputs for DC volts.
Sep 19, 2009 | Sony STR-DA50ES Receiver
93 MX6 throttle body is Popping, loud,sounds like a diesel
Sounds like the pipe/connection from the exhaust manifold to the EGR valve that is located at or near the throttle body has a leak. That would make a loud popping noise.
Jul 15, 2009 | Maybach 62 Cars & Trucks
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Schwinn Original  Airdyne Logo
59 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
