Question about Pegasus Lyndhurst Roman Tub Faucet 883-0016 Oil Rubbed Bronze
How do I fix the handle for the hand shower to turn it off and on
Hand shower handle turns, but does not turn the shower off. When I turn on the main tub faucet, the water only comes from the hand shower. It used to work.
    Master:
  • 574 Answers
Chalk in faucet dismantel and clean .
Posted on Jun 14, 2014
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Moen old shower faucets
Turn off the water to the house undo the screws. Pull out the cartridge. Bring it to any plumbing place or builder supply. Hand it to them they may hand you a new one free without a word being said. This has been the way for decades now. Install the new cartridge.
Nov 29, 2013 | Moen & One Handle Tub & Shower Faucet
Cold and hot water are backwards
You can take the handle off,and turn the water off. Pull chrome collar off,take large nut off with your hand only. Pull cartridge out and flip it 180 degrees.
Apr 01, 2013 | Delta & Single Handle Shower Faucet
SINGLE-HANDED SHOWER FAUCET. TURNED ALL THE WAY TO HOT WATER ,ONLY COLD WATER COMES OUT - WHY???
Take the handle off and turn the stem buy hand and see if you get hot water. If you do then the handle was installed wrong or has loosened to the point where in is out of possession.
Feb 08, 2011 | Home
Leaking hand shower
If it is leaking right where the hose connects to the hand shower, there is usualy a rubber washer inside that may have shifted or need to be replaced. Overtightening is the number one cause for leaks on these. I would try to repair before replacing, as hand showers are costly. Hope this helps.
May 04, 2010 | Home
The water does not turn off
the faucet handles is what turns shower on and off. if nothing to shut it off, it will keep running.
Apr 18, 2010 | Delta & Single Handle Shower Faucet
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Sterling faucet in stall shower how do you get the handle off
Unscrew those screws and the handle will either pull off or unscrew.
Jan 26, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Pegasus Lyndhurst Roman Tub Faucet 883-0016 Oil Rubbed Bronze Logo
133 people viewed this question
Top Pegasus Home Experts
john h
Tom Chichester
Are you a Pegasus Home Expert? Answer questions, earn points and help others
