Question about RCA L37WD12 37 in. LCD HDTV
RCA LED42C45RQ 42" LED LCD HDTV Shutting Off by itself
Why does my RCA LED42C45RQ keep cutting off after a few hours of being on? At times it will not come back on even after unplugging in from one outlet into a different one.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
These flat panel tv's from china have cheap capacitors. Check to see if any capacitors have pushed up top, this indicates blown or dry capacitor. Replace with exact value, in the power supply area (is where they go bad). TV has a monitoring circuit, and if standby (or ready voltage) is not adequate, tv will shut off or stay in standby mode. Little tired today, so hope that gives you an adequate answer.
Posted on Feb 14, 2014
4 Suggested Answers
  • 102 Answers
SOURCE: Need a users manual for a RCA 42'' diagonal 1080P LCD HDTV.
Hi here is a link to the manual for your tv. please rate me i need 3 more to get my badge thank you
Posted on Feb 02, 2010
  • 277 Answers
SOURCE: MY 32 INCH RCA LCD HDTV KEEPS TURNING ITSELF ON.
Carol
These units bave a bad power supply. To get it fixed is easy.
Take it to a Servicer center where they repair tvs.
Since there are no srevice manuals they will not be able to repair this unit. With the Work Order in hand call 1-877-297-8391 and they will send you a tv.
Ps.. Make sure you get a work order or a copy.
Posted on Jul 21, 2010
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
Why did my Quasar TV (1993) picture go out again, blue line across the screen? We had it repaired, 3 months later no picture, same blue line.
Sounds to me like something else is causing those parts to fail. It should be under warranty but depends on the repair shop. Why not just buy a new one.
Here are some choices for a new one:
RCA 42 LED42C45RQ Class LED 1080p 60Hz 3 4 ultra slim HDTV
Why did my Quasar TV 1993 picture go out again blue line across the screen...
LG 24 Class 23 6 Diag LED 720p HDTV Black
RCA LED32G30RQ 32 720p 60Hz Class LED HDTV Walmart com
May 29, 2016 | Quasar Televison & Video
Hi, I would really like to thank you for your assistance and for responding, I really appreciate it. I have attached a photo of my tv power supply can you tell me where is the backlight inverter
back-light inverter will be a circuit part of the SMPS. It is not repairable. But; where is the photo of your TVs power supply. I can't see anything here.
Nov 21, 2015 | RCA LED42C45RQ 42" LED TV 1920x1080, 60...
Rca picture
Very bad symptom indeed.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations.
Aug 12, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
WHY MY LED LCT TV WONT TURN ON
Power supply regulator board problem. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 21, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
42" LED42C45RQ need volume configuration
Hi Jennifer,
Settings of bass, treble and equalizer is a matter of personal choice. You can set them to your liking. Alternatively you can choose the sound mode ( like music, movie and theater ) of your choice. The balance setting off course must be in the middle or zero position so that both the speakers give equal amount of sound. In equalizer the extreme left column represents the low frequency sounds like the sound of drums. As you move rightwards the sounds go on becoming finer and finer and the extreme left column represents the fine sounds of the instruments like violin and sitar. Somewhere in the middle is there is human voice also. Play some music, try varying each column and see the effect. Good luck.
Jan 19, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sound keeps cutting out
Hello Shellyfoster:
The issue sounds like a firmware update is needed for the small signal board.
Aug 14, 2008 | RCA L42WD22 42 in. LCD Television
RCA L37WD12 37 in. LCD HDTV Logo
185 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
