Question about Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2006 2007 2008
Transmission won't shift p2767
Input/turbine speed sensoe B defect
  • Mercedes-Benz Master
  • 694 Answers
Bad valve body seems to b the culprit here
Posted on Mar 02, 2014
I have two code error on my jeep grand Cherokee 2007 idle air-control p0507 x3 of them & p2767 input/turbine speed sensor B, could you help me get idea, of what it is?
code p 0507 refers to idle speed control (ISC) system rpm higher than expected==causes -wiring--ISC actuator/IAC valve --throttle motor -- throttle valve tight / sticking---ECM
it als o refers to idle air control(IAC) system--circuit low===causes --wiring short to ground --IAC valve ---ECM
code p 2767 refers to transmission input shaft speed sensor/turbine shaft speed (TSS) sensor B---no signal===causes --wiring---transmission input shaft speed sensor /TSS sensor
Mar 26, 2016 | Jeep Cars & Trucks
2006 Jeep Grand Cherokee. DTC P2767. Is the probable cause in the transmission or external?
the code means.
to do the tests listed in the fsm. book, not guess.
we do the tests, and find out if the cause in in the transmission
the TCM or the TCM sensors or the solenoid drivers or solenoids
or the actual transmission internals.
why guess? why ask folks to guess. who are blind.?
ever seen the book, and read , the chapter on A/t trans on car tests?
alldata.com or
free
wk jeep
here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
official.
https://www.techauthority.com/en-US/Pages/FacetSearchResults.aspx?make=Jeep&year=2006&model=GRAND+CHEROKEE+BASE&engine=3.7L+MAGNUM+V6&producttype=Service+Manuals&ptCatId=3083
i guessed drive line... so....
the book hints at....
- Faulty Input Speed Sensor 2 ,.is dead.
- Input Speed Sensor harness is open or shorted
- Input Speed Sensor circuit poor electrical connection
The Input Speed Sensor 2 is one of the two hall effect speed sensors that are used by the Transmission Control Module (TCM) to calculate the transmissions turbine speed. Since the turbine speed could not be measured directly, two of the drive elements are measured. Two input speed sensors are required because both elements are not active in all gears.
May 14, 2015 | Jeep Cars & Trucks
Please I have P2767 Code turbine speed sensor no signal so please my car its jeep grand cherokee model 2008 can you help me to know where is it? so i can replace it?
This is your input speed sensor, there are 2... one for input one for output.
Photo attached showing location on gearbox/transfer box
Nov 06, 2014 | 2008 Jeep Cherokee Grand
How do i fix a dodge neon code p0715 ?
Could be any one or more of these problems,but the only way to know sure is to take it in to a transmission shop.Common Problems That Trigger the P0715 Code
  • Defective Input/Turbine Speed Sensor
  • Defective Shift Solenoids
  • Defective Engine Coolant Temperature Sensor
  • Defective Valve Body
  • Dirty transmission fluid that restricts the hydraulic passages
Aug 03, 2014 | Dodge 2003 Neon SXT
What does code p2767 means for a cls 500 mercedes benz
P2767 input/turbine spped sensor B circuit no signal
This is a TRANSMISSION CODE
Apr 12, 2013 | 2004 Mercedes-Benz Mercedes Benz E Class
2001 PT Cruiser Automatic won't shift gears
OK... brains are expensive. It sounds like your PT STARTS OK, but keeps your TRANSMISSION locked.
Many transmissions have a 'lock' that is coupled to the car BRAKES. So the transmission may not allow SHIFTING if the BRAKE SWITCH is not sensed as 'brakes applied'.
APPLIED BRAKES = OK TO START/SHIFT. So it's possible a defective switch is your problem?
Find really GREAT information here:
How To Solve The PT Cruiser Transmission Problems
And there is this: "You Probably have a 604 41 TE auto trans (this is a four speed automatic trans)and if this is the case. Then you need to have the input and the output turbine sensor's replaced,(aka speed sensor) same thing different name. These sensors are cheap and have a high failure rate due to high temps the trans produces."
Now see this:
Transmission not shifting 2001 Chrysler PT Cruiser
and more here:
How to replace 41 TE auto transmission in an 01 pt cruiser neon pt 1
While you are at YOUTUBE search for:
"PT Cruiser Automatic transmission" won't shift
Anthony
Feb 04, 2018 | 2002 Chrysler PT Cruiser
Hi sir, i want some details related to the gear
P0700 Transm.Contr.System Malfunction 17084
P0702 Transm.Contr.System Electrical 17086
P0703 Torque Converter/Brake Switch B Circ Malfunction 17087
P0705 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction 17089
P0706 Transm.Range Sensor Circ Range/Performance 17090
P0707 Transm.Range Sensor Circ Low Input 17091
P0708 Transm.Range Sensor Circ High Input 17092
P0710 Transm.Fluid Temp.Sensor Circ. Malfunction 17094
P0711 Transm.Fluid Temp.Sensor Circ. Range/Performance 17095
P0712 Transm.Fluid Temp.Sensor Circ. Low Input 17096
P0713 Transm.Fluid Temp.Sensor Circ. High Input 17097
P0715 Input Turbine/Speed Sensor Circ. Malfunction 17099
P0716 Input Turbine/Speed Sensor Circ. Range/Performance 17100
P0717 Input Turbine/Speed Sensor Circ. No Signal 17101
P0721 Output Speed Sensor Circ Range/Performance 17105
P0722 Output Speed Sensor Circ No Signal 17106
P0725 Engine Speed Inp.Circ. Malfunction 17109
P0726 Engine Speed Inp.Circ. Range/Performance 17110
P0727 Engine Speed Inp.Circ. No Signal 17111
P0730 Gear Incorrect Ratio 17114
P0731 Gear 1 Incorrect Ratio 17115
P0732 Gear 2 Incorrect Ratio 17116
P0733 Gear 3 Incorrect Ratio 17117
P0734 Gear 4 Incorrect Ratio 17118
P0735 Gear 5 Incorrect Ratio 17119
P0740 Torque Converter Clutch Circ Malfunction 17124
P0741 Torque Converter Clutch Circ Performance or Stuck Off 17125
P0748 Pressure Contr.Solenoid Electrical 17132
P0750 Shift Solenoid A malfunction 17134
P0751 Shift Solenoid A Performance or Stuck Off 17135
P0752 Shift Solenoid A Stuck On 17136
P0753 Shift Solenoid A Electrical 17137
P0756 Shift Solenoid B Performance or Stuck Off 17140
P0757 Shift Solenoid B Stuck On 17141
P0758 Shift Solenoid B Electrical 17142
P0761 Shift Solenoid C Performance or Stuck Off 17145
P0762 Shift Solenoid C Stuck On 17146
P0763 Shift Solenoid C Electrical 17147
P0768 Shift Solenoid D Electrical 17152
P0773 Shift Solenoid E Electrical 17157
P0790 Normal/Performance Switch Circ Malfunction 17174
Dec 20, 2010 | 2006 Renault Fuego
Transmission code error P2716
The computer wants to know if the transmission is working properly. So it reads the speed of the input shaft and compares it to the speed of the output shaft. It knows which gear you're in because it commanded the transmission to shift into that gear. The turbine speed refers to the torque converter. That's the device that transfers power from the engine to the transmission. Think of two fans facing each other. Turn on one fan and the blades on the other fan will spin. The fan that ISN'T turned on is the turbine. So, with the input shaft or turbine speed, the gear selection, and the output speed, the computer can calculate how efficiently the transmission is working. If the speed is off, it knows that something is slipping inside the transmission. It can then try to boost the fluid pressure to compensate. If that doesn't work, it sets a different trouble code, usually a P0716 code means that the computer has detected a value for the input sensor that's either out of range (way too high or too low), or there's a circuit issue (bad wiring, etc. Should probably get it to a repair shop ASAP before damage is done.
Sep 19, 2009 | Toyota Corolla Cars & Trucks
2004 e500 Mercedes trans problem code-2767 need help!!
The code P2767 definition is ,
Transmission input shaft speed sensor?turbine shaft (TSS)sensor B no signal..
Now in English it means the speed sensor is either faulty or bad connection,I would suspect the sensor, but worth getting checked by a transmission specialist,
Darren DCS
Jul 17, 2009 | 2004 Mercedes-Benz Mercedes Benz E Class
Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2006 2007 2008 Logo
214 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
