Question about Riso Office Equipment & Supplies
Riso GR3750 ghost images on front and back of paper
I have a Riso GR3750, first prints always come out fine but subsequent ones have smudging on the back of the paper, the same image as the one printing, plus a ghost image of the same as the print running from about halfway across the paper to the left. Have tried wiping the roller and lightly the same with the master but no luck. Any ideas?
5 Suggested Answers
  • 34 Answers
SOURCE: When running 11 x 17
check and clean the pressure roller.see if that helps.
Posted on Jul 30, 2008
Inkworks
  • 87 Answers
SOURCE: HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Posted on Nov 21, 2008
  • 823 Answers
SOURCE: After making 'Masters' my RISO
It sounds like the person who made the "masters" on your copier has forgotten to change the settings back to the normal print option. There is a setting on copiers to print "masters" which looks similar to a double image or an image distortion. Masters created with this function clean up the print quality when printing large numbers of copies on a commercial copier.
All you have to do to fix this problem is to change the print settings back to normal on the copier unit itself. Try pressing the "C" (clear) button on the copier or the "reset" button to bring the settings back to the default normal print function. If this does not reset it back to normal printing, you will need to scroll the options on the copier machine to find the "default - normal print image" setting and change it back manually.
If you have the user manual for your machine you can find the instructions for returning the unit to default print choices under copier settings.
Posted on Jun 24, 2011
turicopy2011
SOURCE: Print position on RISO HC5500 is shifted to the far left edge.
usually I have a problem with the position of the print, is shifted to one side.
what can i do?
Posted on Nov 22, 2013
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Riso GR3750
this copier can not print envelops
Jul 13, 2012 | Riso RZ220 Duplicator
Riso graph GR3750 marca falla t11 necesito asesoria para solucionar este problema. O es necesario llamar a soporte tecnico ??
"Risograph GR3750 marks to fault T11. I need consultation to solve this problem. Or it is necessary to call to technical support?"
Error T11 means: Call service.
Here some details of the error which may help to solve it: Pressure Control Motor Lock • In 100ms from turning ON of the pressure control motor, the encoder sensor cannot detect a pulse. • In 5 seconds from turning ON of the pressure control motor, the pressure centering sensor is not turned ON/OFF. • When the fuse of the main power board is gone.
Feb 28, 2011 | Riso RZ220 Duplicator
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Riso V8000
need drums for V8000
Jul 26, 2008 | Riso RZ220 Duplicator
Margin shift
If it is a GR or FR it is out of timing.
Jan 29, 2008 | Riso RZ220 Duplicator
82 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
