Question about Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2006 2007 2008
Ml350 transmission won't shift code p2767
When I step down the accelerator it keeps the same gear.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 64 Answers
Check the oil level in the gearbox if this is to low it wont shift
Posted on Mar 16, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mercedes-Benz Master
  • 1,449 Answers
Check the electrical plug going into your gearbox ,its contacts may need cleaned with electrical contact cleaner.but check the fluid level first as it can be low. if so top up with the correct fluid.
Posted on Aug 09, 2014
Where is the passing gear on a 2003 Mitsubishi Diamante
'Passing gear' is a term that means the transmission is down-shifted to a lower gear (e.g., from 5th gear to 4th gear) for improved acceleration to pass another vehicle. There is no physical component called a passing gear in the transmission.
To engage the 'passing gear' with an automatic transmission should require nothing more than pressing the accelerator pedal down firmly. The transmission should downshift automatically to the next lower gear (sometimes it will downshift two gear ratios, depending on your speed and how far you depress the accelerator pedal).
Aug 09, 2017 | Mitsubishi Cars & Trucks
Transmission won't shift p2767
Bad valve body seems to b the culprit here
Feb 14, 2014 | Mercedes M-class Ml Ml350 Ml550 Ml63...
Transmission
Tcc, or transmisson control module is what pops into my head, but the codes state that:. p2767 = speed sensor a....p2768 speed sensor b or Torque Conv Clutch selonoid.
Dec 10, 2013 | 2005 Mercedes-Benz CLK-Class
I have a 1996 dodge ram 1500 5.2L v8 with a rebuilt transmission about 2000 miles ago. The truck will accelerate good until 2nd gear and falls on its face it shifts rough 3rd to 4th gears and when you put...
I hate to tell you but it sounds like your transmission was rebuilt incorrectly and need to be corrected or tossed and start anew, new transmissions for your truck are roughly $1,600. I'm sorry to hear about your problem.
Sep 26, 2013 | Cars & Trucks
Wont go in 2nd gear
If it will go into all other gears but not second, the transmission may have damage like a bent shift fork, damaged gears and/or shift drum. If the bike has been raced or accelerated hard and gear shifts have been missed, it most likely has transmission damage and the engine will have to come out and be torn down in order to repair. If the bike was hopping in and out of second gear before it stopped going into second, the transmission is most likely damaged.
One more thing to try is to take the shift lever and push momentarily down or up on the lever and see if it smoothly returns to its original center position. If it does return to the center position the lever is not sticking and ir it does not return to center position then the shift lever is sticking and that will keep the trans from up or down shifting.
Feb 20, 2013 | 2006 Suzuki GSX 1300 R Hayabusa
F250 1998 light duty won't shift out of park
For car not changing gears and not shifting out of park mode ,it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
NO REVERSE ON TRANSMISSION
http://alltypesofpartsreplacing.blogspot.com/2012/12/no-reverse-on-transmission.html
Transmission fluid leak, transmission gears slip,
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-fluid-leak-transmission.html
These will help.
Thanks.
Dec 06, 2012 | 1998 Ford F250 SuperCab
1995 eagle talon manual transmission i'm able to put my clutch down and shift gears, but car wont accelerate
Something is broken, that is for sure, pull the transmission out and first look at the clutch plate.
Jul 08, 2012 | 1995 Eagle Talon
How can you tell what trans is in 01 grand cherokee laurado 4.0
Here is an article I found talking about the Transmission. The second generation Grand Cherokee: 1999-2004 Jeep WJ The first Grand Cherokee was redesigned in 1999, for lower production cost and greater performance and reliability; it was Chrysler's first use of an electronic bus to replace individual wires throughout the body.
Jeep five-speed automatic transmission
An all-new, electronically-controlled transmission with five forward ratios including an alternate second gear ratio for improved performance for passing and better fuel economy is available with the V-8 only, and was designed specifically for Jeeps.
The transmission features unique characteristics such as a tall, 3.00:1 first gear that gives the driver better initial acceleration. Real-time driver adaptive shifting fine-tunes the shift pattern to the driver, while an alternate second gear ratio gives the driver five forward ratios. During acceleration, second gear has a ratio of 1.67. Depending on speed and throttle position, both this gear and an alternate 1.50 second gear ratio are available for kick-down operation, making the down-shift smoother. Its reverse gear ratio is equal to the first gear ratio, to allow for heavier loads.
Other features include three planetary gear sets that combine the widest range of gear ratios available in any transmission in its class. Combined with precise step selections, this brings smooth shifts and maximum power and optimal fuel economy.
The transmission is built at the Indiana Transmission Plant in Kokomo, Indiana, in an all-new 1.2-million square-foot (110,000 m2) facility.
Mar 01, 2011 | 2001 Jeep Grand Cherokee
Mercedes M-class Ml Ml350 Ml550 Ml63 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2006 2007 2008 Logo
224 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
