Question about Sewing Machines
I have brother compal star 732 and have broken the spool case
3 Suggested Answers
SOURCE: Brother sewing machine model 732 (pretty old
have you checked the reverse lever to see what position it's in?
if the needle broke at the tip end check in the bobbin area for needle fragments
it is possible that a broken needle can jam up or even get the machine out of time.
it may need to be serviced
Posted on Aug 03, 2011
Testimonial: "There did not seem to be any needle fragments But this reply got me to clean and service all the innards, whereupon it now works Thank you! B"
SOURCE: -i have compal opus 11
try these sites
sewingpartsonline.com
amapparelsupply.com
a1sewingmachine.com
sewingsupplywarehouse.com
Posted on Sep 21, 2011
Hi there, I have an old Empisal Compal ACE 765 sewing machine. After servicing the machine, I cannot get the bobbin and bobbin casing to line up in the correct timing with the needle. And I do not have a...
You can find a manual for for your machine in the link. In the photo below it show the same type of bobbin as your machine. It may or may not help you. It is a little fiddly if you have never done it but take your time and have lots of patience. Having a manual for your machine is invaluable.
Joness Brother Electronic Compal Ace Model 765 Sewing Machine Instruction...
Aug 02, 2017 | Sewing Machines
How to change Brother compal galaxie 870 sewing machine needle default that starts on the left to default to the middle
Some machines have the left setting as the default. Those machines have the bobbin case that is installed from the left side of the machine. For most purposes, this default cannot be changed to center. Machines that have the bobbin case installed from the front of the machine generally have the needle center default position. However, it appears to be a newer model machine (post 1970), so there is a good chance your machine has a needle position setting.
Brother Compal Galaxie 870 Service Manual free download schematics...
Brother Sewing Machine Manuals Instruction and Repair Manuals
Feb 10, 2017 | Brother Sewing Machines
How to replace a broken spool pin on a brother xr40 sewing machine?
Search for:
Make Model replacement parts
Vendors like Sewing Parts Online may have what you need. If not, you may be able to fashion a replacement using a cut-off chopstick, a plastic drinking straw, etc. Some machines work just as well with a stand-alone thread spool set off behind the machine. Sewists sometimes will set the thread spool inside a jar behind the machine.
Feb 09, 2017 | Brother Sewing Machines
Spool pin broke and fell into machine brother vx-810
If you try to take the case off, you'll void the warranty. If you don't mind doing that, just take the case off, retrieve the bits (and take the opportunity to de-grunge and de-lint), and put a new spool pin on.
Jan 15, 2014 | Brother Sewing Machines
How do i take the case off my brother xr-65 to replace my spool pin and spool cap
I don't have that particular Brother but I have on that is similar.
Start by taking all of the screws out of the back that you can find (they're in deep holes, so look carefully). Then look at the bobbin area and you'll probably find one more. Finally, take the feet off of the bottom of the machine (not the presser foot, the feet that sit on the table), you'll likely find that there is a screw through the middle of the foot that also holds the case in place.
Best of luck
Sep 10, 2012 | Brother Sewing Machines
Brother sewing machine model 732 (pretty old machine) compal star My machine was sewing forward up to today. I broke a needle changed that since when it wants to go backwards...any ideas what to do I have...
Aug 03, 2011 | Brother Sewing Machines
Needle hitting the metal spool housing underneath, mis-timing?
the timing has, gone there is a screw holding the spool carrage on to the shaft lossen this a little so that it still grips but will turn, the neddle should pass the point on the spool case just after the eye comes level with the spool point and hence pick up the lower cotton and just miss the spool case, after re timing turn over by hand to ensure nothing is hitting anything else.
Aug 15, 2009 | Brother Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
