Question about Marantz Audio Players & Recorders
Marantz SR5004 shuts off after a second or less
The only thing connected is power. The display shows briefly then goes out. Then when pushing the power button it just clicks with no display. Unplugging it and plug it back in will cause it to show the display briefly again.
    New Friend:
  • 30 Answers
It's going into safe mode check the power supply
Posted on Feb 15, 2014
5 Suggested Answers
SOURCE: Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
Posted on May 04, 2009
sonicboomele
  • 1557 Answers
SOURCE: For no reason I know of, my Marantz SR8001 will
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
Posted on Oct 14, 2010
SOURCE: Marantz SR5004: display says 7.1 CH input source
Look on your remote. There is a button top right that says 7.1. Hit it. Reselect input and surround and you should be good to go.
Posted on Jul 12, 2011
SOURCE: What is the Best way to connect a Wii to the Marantz SR5004
the best soution is to connect them.hope this helps.kind regards,KJ
Posted on Dec 19, 2011
How do i change a power supply
A hi-fi receiver typically does not have a power supply that you can simply remove the broken one and plug the new one in. They are not designed like desktop computers. Try to locate and fix the broken component first.
Jan 13, 2015 | Marantz Audio Players & Recorders
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
Sep 27, 2014 | Marantz SR5004
My sr5004 marantz is in standby with the indicator is blinking on the front how do i get ride of it
Power the unit down and remove all cables. If it still blinks when you power back on, you probably have a PS failure. I could not locate any fuses or circuit breakers on mine and had to return for service. There is a factory reset that can be performed by pressing and holding the surround mode and clear buttons on the front panel at the same time for 3 seconds.
My marantz sr5004 is flashing the standby light and wont switch on
Switch off the unit. Then hold down Sorround, Exit, Memory & Clear buttons all together and then switch on the power. This should work.
Apr 22, 2012 | Marantz SR5004
Dec 05, 2011 | Marantz SR5004
Marantz SR5004: display says 7.1 CH input source direct. I can't change the sources at all. TV is working but no sound. I think my kids hit a few buttons, but I can't reset it. Thanks
Feb 11, 2011 | Marantz SR5004
New tv, new marantz sr5004, hdmi cable- no sound out of speakers
To really help you would require a bit more detail. HDMI is the video part of the signal - the audio part may require additional cables. Also, source material may play a role. I'd start by seeing if you have some audio outputs from whatever your source is and connecting those to the Marantz. Beyond that, I'd need more info to be sure I was giving decent advice.
Oct 22, 2010 | Marantz SR5004
For no reason I know of, my Marantz SR8001 will not come on and the display will not light up. It will not respond to activation using the power button on the display panel, or the power activator on the...
send it in
best luck
Oct 14, 2010 | Marantz SR8001
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
Jan 26, 2010 | Marantz Audio Players & Recorders
166 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
