Question about Brother HL2280DW: HL-2280DW Wireless Laser Printer
Still says replace toner even after new one inserted
Inserte new toner and printer continues to say replace toner
Mix-it-up
  • 832 Answers
SOURCE: printer problem
Try to unplug the printer from power. Wait a minute. Take all carts out. Close ink cover. Replug printer to power. Machine demands carts. Insert carts as demanded.
If you still have this error this could be due to generic ink carts. Ink may have stained the led control and the ink assy has to be replaced!
Posted on Nov 10, 2007
daemonguy
  • 118 Answers
SOURCE: False detection of toner low
The only remedy you have now is to change the sensor , for this you have to refer to the product manual you can download it from
http://www.brother.ca/en/products/pdf/QSG/HL2030-QSUG.pdf
Good Luck
Posted on Dec 06, 2007
yalmer
  • 552 Answers
SOURCE: I have a brother HL-2070
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
Posted on May 01, 2008
  • 5 Answers
SOURCE: low toner/toner empty
I kept getting the dreaded Empty Toner warning which essentially locks up and makes your machine unusable.  I used a little logic and applied the tape from previous Brother cartridges that is over the fill hole and it worked like a charm.  I'm pretty sure any tape would work as I cannot see a magnetic device in the tape they use.  It's obviously a proprietary technique to keep people following the above advice and but more Brother Cartridges.  Buy refill kits and tape the plug holes my friends!
Posted on Oct 15, 2008
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
Aug 16, 2014 | Brother MFC-7440N Laser Printer
How do I clean the rollers on dell 1720?
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Aug 10, 2014 | Dell 1720dn Laser Printer
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Printer is reading INSERT THE TONER CARD, after replacing the toner cartridge
You need to replace the chip card that came with the toner.
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=LFF6020W/GBB&dct=QAC&faqview=1&refdisplay=QAC_80832&refnr=0080832&scy=GB&slg=ENG
May 14, 2012 | Philips LaserMFD 6020 (LFF6020)
The toner light on , and no print
The toner probably needs replacement. You can try to remove the toner cartridge, shake it, and insert it again to continue printing.
Jul 19, 2010 | Brother HL-2040 Laser Printer
Printer reports 'Toner Empty' error whereas actually the toner is not empty.
If its printing then it will continue printing till the toner finished.
If you have refilled then the message will continue may damage the printer also.
If the toner is already exhausted. We request u to replace the Toner from market ( not from the New Printer Box). Sales Toner
Dec 10, 2009 | Samsung SCX-4216F All-In-One Laser Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
How to rotate toners
To rotate the toners:
1 press the down arrow until reset menu appears press the right hand arrow once
2 Scroll through the menu until change toner appears.
3 Toner C appears first continue scrolling until you reach the desired toner eg K for black then.
4 Press the right hand button and the red light will appear on yhe main button.
5 Open front door and change toner.
Works for me after hours of searching. Hope it works for you.
Jul 03, 2008 | Epson Aculaser C1100 Printer
Insert Yellow toner
There is a cheap under the toner... it is probably corrupted... with a screw driver you should take it out and replace it with the old cartdrige toner.
Nov 08, 2007 | Dell 5100cn Laser Printer
Brother HL2280DW: HL-2280DW Wireless Laser Printer Logo
35 people viewed this question
Top Brother Computers & Internet Experts
shaun
shaun
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
