Question about Panasonic KX-TM150B Digital Answering Machine
PhoneMate Answering Machine 3900 does not record greeting.
Normally you press "greeting" speak into mic, press "greeting" to end recording and it saves and plays your greeting. Suddenly it does not do that. It does not end the recording unless I press "greeting" button twice. And it does not playback the greeting. I cleaned head/capstans and replaced tape. Problem persists. The "memo" function works as normal, recording and playing back memo, so it is not the mic. Any ideas?
3 Suggested Answers
CORDLESSGURU
  • 106 Answers
SOURCE: greeting was somehow erased
Hi Sherrie, I am sorry to hear about your husband, I will do what I can to help. I am fairly confident on that model that if you push the greeting button, then delete it will erase the message for good. Also, if the memory power failed, then it would reset to the default greeting and erase all messages and greetings. However, if the unit has options for multiple greetings (ie. default greeting, greeting 1, greeting 2, etc., then perhaps the default greeting may have been selected, while your husbands greeting is still there but is recorded under say greeting number 1. If that is the case, you can select it to play his greeting instead of the default greeting to have it play. I would find out for you but my computer is having trouble opening the manual on the Panasonic site, so here is the link. Look under "greetings" in the index. Hope I helped. Thanks, CG http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
Posted on Feb 14, 2008
  • 34 Answers
SOURCE: Hi, looking to record a greeting on panasonic answering machine
Found owners guide on line.
Posted on Oct 13, 2009
How do I put my own message in my answer machine .?
you have not bothered to give the make and model of your phone so this answer is relevant to uniden dect 1635 but will be a guide to your unit as well as most use the same format
recording a personal greeting (2 to 30 seconds long)
1--open the menu with the phone in stand-by
select answering setup, then record greeting
2--press menu/select to start recording Wait until the system says --"record greeting" before speaking
3--press menu/select to stop recording. The system plays back your new greeting
4--- to keep the message press end
to re-record it press menu/select
in your manual look for the section " using answering system" or "personal the greeting"
Jan 07, 2016 | Lands Phones
I would like to change the answering machine message
Record a Personal Greeting
Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
Aug 21, 2013 | Panasonic KX-TGA101S Cordless Handset
How to put my own voice on answering maching?
Open the menu with the phone in standby.
Select Ans. Setup, then Record Greeting.
Press MENU/SELECT to start recording.
Wait until the system says "Record greeting" before speaking.
Press Menu/Selectto stop recording.
To keep the greeting, press End.
To re-record it, press Menu/select.
Hopfully this works for you
Jul 05, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do I make answer message
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
May 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I change the greeting message?
You can record your own greeting message (max. 2 minutes) that is played when the answering system answers a call. If you do not record a greeting message, a prerecorded greeting message is used. 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm (8 inches) away from the MIC. 4 To stop recording, press {STOP}.
Mar 08, 2011 | Panasonic KX-TG5632 Phone
My answering machine message is out dated and needs to be changed how do you do it?
Recording your greeting
message
message (max. 2 minutes). If you do not
1 {GREETING REC}
from the MIC.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
I want to change my answering machine greeting
For the DECT2180, press Mesage/Mute on any handset to access the answering system. Wait for the announcements to be finished or press 5 to skip. Then press 8. Wait for the message "record greeting" then begin speaking. Press 8 to stop recording. The system will play back the greeting. Press End to save the greeting and exit the system.
For the DECT2080, press and hold Greet on the base. When you hear "record greeting", start speaking your message. Press Greet again or the play/stop button to stop recording your message. Press Greet again to play back the current outgoing message.
Which Uniden do you have? There are several models. Manuals for all of the current ones are here: http://www.uniden.com/index/manuals_results.cfm?cat=59 .
Most models will be similar. Setting a new message when you call into the system is a totally different issue and not all Uniden phones support the feature. Read your manual.
I hope this helps.
Jan 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i record a personal message on the answering machine of my Uniden DECT1480?
1. Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
2. Press 8 (RecNewGreeting).
3. Wait for the system to say "Record greeting," then begin speaking.
4. When you're finished, press 8 to stop recording. The system plays back your new greeting.
5. To keep this greeting, press End. To re-record it, go back to step 2.
Or you can get the manual on the link below page 17.
Good Luck
Nov 08, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
I need remote instructions for the phonemate 3900 am
The remote function will allow you to control your answering device from anywhere. On the Phonemate brand, you simply "key in" your answering machine's PIN number when your answering machine picks up your call. From there you can playback your messages, erase messages, record a different greeting and more. On some models the "default" PIN code is stamped on the bottom of the unit. Some units have a battery backup to retain messages if you have a power outage. If your PIN code IS printed there, and you have forgotten your PIN code, simply remove the battery from the bottom of the unit, wait a minute, and reinstall the battery. Your PIN code will be reset. I have attempted to get a manual for your unit and the best on the web so far has only come up with the address as follows
Phonemate Answering Machine Sales & Service Center 2321 Morena Blvd. San Diego, CA 92110 Phone:(619) 276-7312If this helps, let me know. We'll dig a little deeper.
Len
Mar 01, 2009 | Lands Phones
Panasonic KX-TM150B Digital Answering Machine Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
