Manual required for sony cassette recorder slv e730
I can't get my recorder to accept the tape
  • Audio Player... Master
  • 1,258 Answers
Dirty in detection switch. Check with Stereomanuals.com
Posted on Sep 29, 2015
robotek
  • 1512 Answers
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: Bob@Vintage-Electronics.cc
You could have a go at freshening up the belts yourself:)
regards
robotek
Posted on Jul 12, 2008
  • 4234 Answers
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Posted on Oct 07, 2008
SOURCE: Tape recorder belt
Use a durable rubber band. It works for a while!
Sudhir
Posted on Dec 15, 2008
CLARKPINK55
  • 71 Answers
SOURCE: Sony dual cassette recorder, cassette doors hard to open,
change al the belts that will sort it
Posted on Dec 17, 2008
djtatty
  • 417 Answers
SOURCE: Need to find user manual.
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Posted on Mar 01, 2011
My Sony VCR Model SLV-662HF will not accept cassettes. I am using a universal remote control. The VCR's display shows APC 71501 and 81508. Do these APC codes refer to the VCR or the All In One universal...
The codes are to program the universal remote control to communicate with the Sony VCR. Try programming the universal remote using one of these: 60000 60032 60033 60035
The acceptance of the cassettes may not be related to the use of a universal remote control. If the URC doesn't have the "equivalent" functionality of the VCR's original remote control, you may not be able to use the URC to perform the functions of the original remote control.
Dec 13, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
VCR will not accept cassette.
The loading mechanism may have failed.
Dec 03, 2013 | Sony Slv-662hf 14" Vcr Plus Rmt-v266...
I need a manual for my sony slv-640hf video cassette recorder so I can tape shows in advance Thank you for any help you can give me. :-)
Go to this in your web browser:
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
Enter your VCR model number in the box. Click CONTINUE. The next page has the link to download user guide in PDF format. Click on the link Operating Instructions to download manual.
Jan 28, 2011 | Sony SLV-640HF VHS VCR
Vcr ejects tape when i try to record.
is the erase protection tab removed from the cassette?
if yes there is a square hole on the back of the tape visible when you insert it.
put a piece of sticky tape over this hole and make shure it does not come loose.
it should record fine now when you insert it again.
Aug 30, 2010 | Sony SLV-N51 VHS VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
89 people viewed this question
 Grubhead
Grubhead
