Question about Microsoft Outlook 2010 for PC (885370021134)
Outlook does not start
Does not start
Microsoft Outlook 2013
In most cases it is the corrupted Navigation Pane settings file that prevents Outlook from starting successfully, so the first thing you need to do is to mend it. Here's how you can do this on different operating systems:
1. If you use Vista, Windows 7 or Windows 8, click the Start button. On Windows XP, click Start > Run.
2. Type the following command in the search field:
outlook.exe /resetnavpane
Note: Be sure to enter a space between outlook.exe and /resetnavpane.
3. Press Enter or click on the file in order to reset the Navigation Pane settings and then open Outlook.
Or try to repair your outlook.pst file using Outlook Fix Toolbox
Findit here https://www.fixtoolbox.com/outlookfix.html
Oct 23, 2015 | Microsoft Outlook
Outlook 2010 slow when sending attachments
It could be an outlook add-in. Try starting outlook in Safemode. Close Outlook, Click Start > Run.. type in "Outlook /safe" <--without quotes.
Try resending attachment. If that works close outlook and start it normally.
In Outlook, Click File > Options > Add-ins > GO... (next to Com Add-ins). From here you can go through the list and uncheck what options you don't want.
Jan 04, 2013 | IObit Advanced SystemCare Pro
HOW OUTLOOK 2003 SAFE MODE WORKS
Safe Mode loads Outlook without many of the customization files and add-ins loaded. If Outlook works correctly in Safe mode, the problem is with one of your add-ins or customization files.
You can use one of these methods to start Outlook using a command line switch:
  • Hold Ctrl key as you click the Outlook shortcut.
  • If you use Vista, type outlook.exe /safe in the Start Search field on the Start menu and press Enter.
  • If Run.... is shown on your start menu (any version of Windows) click it and type outlook.exe /safe in the Open field and click OK.
  • Hold the Windows key and press R, then type outlook.exe /safe in the Open field and click OK
Mar 27, 2011 | Microsoft Office Outlook 2003 for PC
Cannot open microsoft office outlook for my e-mail.
Your Outlook could have received a corrupted email that override your inbox folder. Try doing a System Restore.
Mar 17, 2010 | Microsoft Office Outlook 2003 for PC
Outlook 2000 inbox
hello
In thsi case try to open outlook in safe mode
the command is
click on start
run
outlook /safe
if that works fine then there is some issue with the addin
then for thsi close outlook
click start
run
regedit
hkey local machine - software -microsoft-office - outlook - under outlook expand addin
then highligfht add in ione by one and on the right hand side modify the regisrt from any other value to 0 , do all thsi with all the addin and then try to open outlook
Mar 06, 2010 | Microsoft Outlook 2000 (543-00638) for PC
Outlook 2007 upgrade freezes on startup
You say that you have upgraded to Outlook 2007 from Outlook 2003; were you using any personal folders (.pst) in Outlook 2003?
If the asnwer is yes; then were these personal folders created in Outlook 2003 or some earlier version of Outlook? In any case, if the older type personal folders are large in size, these can cause Outlook 2007 to stop responding or freezing.
Close Outlook 2007; right click on the Outlook icon showing in the startup programs bar and choose properties; choose 'Show Profiles'; choose copy profile and then choose this new profile in the 'Always use this profile' option.
Outlook 2007 should now work fine.
May 26, 2009 | Microsoft Office Outlook 2007: Windows
Can't run outlook 2007
Try opening Outlook from run command window
Start > Run > Outlook /safe
If it works fine close outlook
Go to following registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins
Delete the addin key from the regitry
Happy computing :)
Apr 09, 2009 | Microsoft Office Outlook 2007: Windows
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Microsoft Outlook 2010 for PC (885370021134) Logo
24 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
