Question about Eachmall JXD S5300 Retro Console Capacitive Multi-Gaming Rooted 4G White
Not booting main menu
Loading problem
Enter setup boot menu
When you turn your Acer on, there are some options in the very beginning that say "press F9 to enter boot menu" or "press F10" or "press F11" you just need to find out which of the F's is the key to the boot menu. When you already know that just click it 5-7 times while it's loading and you must enter the boot setup menu.
Aug 02, 2013 | Acer TravelMate 3270-6569 Notebook
Acer aspire AME600- UR368 boot menu
To get to the boot menu, you have to press F12, or F8 when you first turn on your computer. If your OS starts loading, you've gone too far and must start over again.
I hope this helps :)
Feb 25, 2013 | Acer Aspire M AME600-UR368 Desktop PC
Boot mgr missing message
I could have told you you were loading Windows 7 by the symptoms. Try running a Malware program with a register edit-register function in it. If you are switching from XP Pro. you will need to clear your register and all command and drive to . Set BIOS to boot from DVD/CD first then set the hard drive to boot second. Windows. Also if you have access to another computer ask microsoft for tech support.
Apr 01, 2012 | Compaq Presario 5000 PC Desktop
Will not boot up
Try with Recovery Console:
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
After restarting windows use a system utility software like RegInOut.
Dec 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
Mac won't go to the main menu
beginning of what?
try booting in safe mode (holding down shift key while booting)
Jun 08, 2010 | Apple PowerBook G4 Mac Notebook
Stuck on loading main boot menu
Hi friend,
Your OS not working because your window file is corrupt ...so reinstall your OS....
Dec 26, 2009 | Computers & Internet
Screen stays black after windows loading screen
Just do static discharge.
Turn off notebook - take out battery. unplug from mains. press and hold power button button for 20 seconds. Try and turn on notebook again
If that will not work. Just keep pressing f8 key after you press power button. YOu will see advanced boot menu. In advanced boot meny select safe mode. Check if you cal load windows in safe mode. If yes then do system restore from (Start-all programs->accessories->System tools->System restore
thanx
Oct 12, 2009 | HP Mini 1000 Netbook
How do i reset my sansa e270
Press and hold the "Power/Menu" button for 15 seconds to reset it back to its original factory default settings.
Sep 24, 2009 | SanDisk Sansa e270 MP3 Player
Can't reboot Compaq/Presario desktop, (power supply is working)
If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
Dec 27, 2008 | Computers & Internet
When I start my computer it lets me get to the menu but gives me a rundell error and then start my main menu after it start loading my main menu starts blinking on and off and I am unable to go to system...
if you have a windows xp CD, > boot with that and choose repair on the first question that appear. run checkdisk on c:. type in the cmd prompt " chkdsk c: /R " wait and restart later. that could fix the problem.
Aug 13, 2008 | Computers & Internet
Eachmall JXD S5300 Retro Console Capacitive Multi-Gaming Rooted 4G White Logo
426 people viewed this question
Top Eachmall Video Game Consoles & Games Experts
James Wishart
Are you an Eachmall Video Game Console and Game Expert? Answer questions, earn points and help others
