Question about Sewing Machines
Janome excel 23x sewing machine
Hi I have a janome excel 23 x and I am having trouble sewing stretch fabric i am using a ballpoint stretch needle and good cotton it sews perfectly on cotton fabric but as soon as i try and sew stretch it won't sew hopefully you can help me. Cheers Sharon
  • 1116 Answers
SOURCE: I have been given my mums janome my excel 23x
This is as close as I can find - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/New_Home_Threading_Diagrams/New_home_2022_Threading_Diagram.htm
Check with local shops that sell this brand for an owner's manual as there is more you need to know about to use this machine.
Posted on Feb 20, 2010
Testimonial: "Thats exactly what I neeed, thanks thanks and more thanks...Trish"
Tally Girl
  • 1129 Answers
SOURCE: sewing two pieces of cotton
Threads underneath is the top thread coming down and not being tensioned enough by the top tension dial. So turn the top tension back to 5 and test sew. Does this produce an even stitch tension top and bottom.
If this then is still giving the looping underneath, recheck that the top thread has seated into the tension discs fully, always raise the pressure foot before threading the top of the machine so the tension discs are open fully.
Also cleaning top tension discs sometimes helps, to do this, turn tension dial right down to zero, raise pressure foot, remove all top thread and "floss" between the tension discs with the selvage edge of a clean piece of cotton fabric, if you get lots of gunk on the fabric edge from the tension discs, then keep cleaning with a fresh bit of fabric. Thread, especially, black or cheap brands, will shed dye particles and this will build up in the tension device with time. You can also clean with some denatured alcohol, just wet the fabric edge and floss again. Just don't get onto any plastic bits.
Now thread up again, set tension to 5 and check that the top thread is in tension by threading down to just before the needle, lowering the pressure foot, and pulling on the thread. It should be firm. If you can't get this to happen at all, then the tension device may have broken and will need to be serviced by a technician.
Also if you don't have a manual for your singer you can download at http://www.singerco.com/accessories/instruction-manuals, just type in your model number and click search.
Posted on Jul 04, 2011
Tally Girl
  • 1129 Answers
SOURCE: My machine which is a
When sewing the material that is giving you trouble, cotton and poly knit, were you using a jersey ball point needle? You need a ball point needle to push between the fibres of a knit rather than a sharp needle which will deflect and not pierce the fabric effectively. There is also "stretch" needles which will work when a ballpoint is skipping stitches, ideal for synthetic knits like lycra and elastane. Your fabric may have elastane in it, some wovens called "mechanical stretch" will contain elastane and won't like a regular point needle.
If you visit this site http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/ you will see that there is a large range of needles for different fabrics and sometimes changing to a different type will solve the skipping stitches problem.
However, it sounds like your machine timing may be slightly out which is then showing when stitching this knit fabric. You could test by sewing a wide zig zag, is the thread locking both sides of the zig zag? Timing between the rotary hook and needle movements is important; I've always taken my machine to a technician for this repair.
Posted on Jul 25, 2011
SOURCE: Janome Decor Excel 5018 Sewing
I just had the same problem tonight for the first time. Does anyone have a solution? I need to finish making Halloween costumes!
Posted on Oct 03, 2011
bargainbox
  • 1388 Answers
SOURCE: Am looking for the instruction manual for the
A manual for your Janome 23X available, with bonus, .....HERE
Posted on Nov 13, 2011
How to sew Lycra on my necchi 522? I'm using a stretch needle. It goes up and down, fabric advances, but does not pick up bobbin thread - so no stitches!
Knit fabric sometimes plays a little havoc with machines. Be sure you are using a brand new needle. Also, ballpoint/jersey needles will usually work better with knit fabrics like t-shirt fabric. For very stretchy fabric like Lycra, you might want to try a Stretch Needle.
Schmetz Needles Needle Guide
Sewing Spandex Tips
If it still will not stitch, check your machine on regular woven fabric with a universal needle. Could be your machine is slightly out of time, especially if you have recently sewn over & hit a pin.
Oct 26, 2016 | Necchi Sewing Machines
Brother se 2700 will not sew on knit fabric
Check that you are using a ballpoint needle, designed for knits. Also, be sure that the thread is not 100% cotton thread.
Jul 15, 2014 | Brother SE-270D Computerized Sewing...
I do really need to buy a stretch needle
Yes, for stretch or knit fabrics you need to use a stretch or jersey needle, they have a ballpoint which will push through the fibres and not pierce them. Right needle for the fabric sewn is critical to good stitch formation and each needle has a use life of 6 hours. Small zigZag stitch will work, straight stitch may pop under wear 10_23_2013_1_18_05_pm.png
Oct 23, 2013 | Sewing Machines
Twin needle tension problem
Hi, Tania
Chances are that you're using a universal point twin needle, designed for sewing on woven fabrics. Twin needles also come with a ballpoint which is what you need for knit fabrics
A ballpoint or stretch needle has a rounded tip that will separate the knit fibers as it penetrates the fabric instead of breaking through them. A universal needle may not catch the bobbin thread on both needles when used on knit fabrics; this is necessary for proper stitch formation.
Nov 06, 2012 | Brother InnovIs 4000D Computerized Sewing...
Janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
Jun 05, 2012 | Sewing Machines
Need to locate a source of blue tipped sewing machine needles. the manual in euro-pro denim machine states needles are best for mending and other fabrics.
Schmetz make a blue coated needle, usually best for denim fabrics as the coating aids the needle in slipping between tightly woven fibres such as denim. It may also be called a Denim needle.
But you shouldn't need to use that needle for most fabrics, just the most appropriate sized needle and either sharp point for wovens or ball point for knits. Perhaps get a mixed pack of both sharps and ball points to start with.
Try this website if you want to shop for needles on line, http://www.sewingpartsonline.com/sewing-machine-needles.aspx they carry a wide range of types, sizes and brands. Klasse and Schmetz are both high quality needle brands. You want the 130/705H system of needles for your domestic sewing machine. These are the norm for 99% of domestic sewing machines.
There are other needle systems for industrial machines (round tops) and EL705 for overlockers, these are extra long but identical shank design at the top. So just make sure you get the regular needles 130/705H.
In terms of what size to use, here is good reference guide on sewing machine needles.
http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/Needle-Sizes.--94.htm
The important thing is to change the needle for each new project, ie about 4-6 sewing hours, as a blunt needle will never give good results. If you always start with a new one, and its the right sized needle for the fabric you are sewing, then you should ensure best possible stitching results from your machine.
If the needle is too big, it will leave holes in the fabric, too small and it will break. If you use a sharp point on stretch fabrics, you'll get skipped stitches. If you sew a lycra knit with a ballpoint and it still skips, then change to a "Stretch" needle, this will also be blue coated ballpoint and helps with skipping and needle deflection.
Then there is twin needles, twin stretch needles, winged needles and leather needles, all for special techniques. Never worth trying to scrimp on needles, I have probably have in excess of 40 packs of different sizes and types in my sewing cabinet.
Hope this helps you out.
and they sho
Sep 24, 2011 | Euro-Pro Denim Sewlution 380 Mechanical...
Needles to buy
Hello dear! This specific machine recommends regular 90/14 needles, although it would fit 75/11 as well. These are the standard needle and can be purchased at an sewing, fabric or craft store, as well as even a larger store like wal-mart or meijer. (sewing aisle, usually in the middle of the store). If you are sewing a woven, non-stretch fabric, choose the UNIVERSAL needles that come in the red package, if you are sewing on knit or stretch material, choose BALLPOINT (or "stretch") needles that come in the yellow package. Personally, I use schmetz needles. A little more, but way better. Get to stichin! ;)
Jun 22, 2011 | Euro-Pro 1100
Sewing machine tension?
Hi! This might be a tension issue, but it also could be caused by the needle. For stretchy fabric you need to use a stretch needle or at the least, a ballpoint needle. (see my tip about which needle to use).
Let me know if this solves the problem, ok?
Happy Sewing!
Robbie
Mar 03, 2010 | Brother XL-6562 Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
