Question about Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman)
Craftman model 247 running problem
Starts runs then stops
    Problem Solver:
  • 29 Answers
Fuel system needs checking
Posted on May 01, 2014
4 Suggested Answers
SOURCE: i have a craftman 42"riding mower,about
Do you have a switch to engage the blades or a lever..... 1st thing check to see if the blade it's jammed on something under the deck
Posted on May 08, 2009
bbreton
  • 437 Answers
SOURCE: craftman lt3000 lawnmower just stop running and
The ignition module on the engine may have gone bad. it may need to be replaced. Plus check air filter to make sure it is clean.
Posted on Sep 26, 2009
BAMOUT
  • 2478 Answers
SOURCE: I HAVE A 6000 CRAFTMAN
Its a fuel problem. Remove fuel line from carb. Remove fuel cap, vent in it is common problem. A small hole in cap.
Posted on Dec 21, 2011
Where is the drain plug on my craftman push lawnmower model #247.374400
There isn't a drain plug on this model. You need to remove the dipstick and tilt the mower on it's side (towards the dipstick) in order to drain. BEFORE you tilt it over however be sure that you drain all the gasoline. You should be able to do this by disconecting the gas line from the carb and draining it into an approved container. CRAFTSMAN 247 374400 Operator Manual Page 16
Jul 30, 2017 | Garden
I have a singer 247 it was sewing really good but started going slower and slower til it stopped could it be the motor
It is more likely that a bushing internally warms up then seizes partially. A good cleaning and lubrication could solve this. To test the motor remove the drive belt and run the motor with no load, see if it slows down if not see idea above.
May 13, 2014 | Singer 7462 Mechanical Sewing Machine
I have a craftman riding mower model 917-273381, It will run & cutt grass good for about 4 to 5 min & then stop. I`ve replaced carb kit & check the kill switch. It still doing the same thing.
How long does it have to sit before it starts again? Does it need to be jumped? If battery is old or not recharging you can loose power. I had a regulator go bad and mine would keep dying. I would charge the battery and mow for awhile then would die again. Have you checked battery and regulator?
Sep 07, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I HAVE A 6000 CRAFTMAN WITH 26 V KOLER STARTS RUNS WITH THE CHOKE OUT . AS SO AS I PUSH THE CHOKE IN IT STOP RUNNING
Aug 31, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My generator starts and runs fine but I keep popping the breakers with tools that shouldn't pop them. this is happening on both sides
a 6250 watt generator isn't as powerful as you might think.
Here is ohms law for Alternating Current. It is different than for Direct Current
AMPS= WATTS÷(VOLTS x PF) I=P÷(E x PF) A=W÷(V x PF) WATTS= VOLTS x AMPS x PF P=E x I x PF W=V x A x PF VOLTS= WATTS÷AMPS E=P÷I V=W÷A VOLT-AMPS= VOLTS x AMPS VA=E x I VA=V x A HORSEPOWER= (V x A x EFF x PF)÷746 POWERFACTOR= INPUT WATTS÷(V x A) EFFICIENCY= (746 x HP)÷(V x A x PF)
Aug 11, 2009 | Coleman Powermate Premium Plus 6250W...
I have a craftman yard vac with a tecmseh 4.5. She has failed to
Hi gr2954;
Lots of the starting problems with 2 cycle engines (weed eaters, blowers, chain saws, etc) are caused by leaving them stored for long periods of time with the oil/gas mixture left in them. what happens is that a residue forms on parts in the carb.
Try the following: empty the fresh gas out of the blower. add a gas stabilizer to the existing gas you plan to put in the blower. You can get this stabilizer at any auto parts store. While you are there get a can of spray start fluid. Put the fresh, modified gas in the blower. Take the spark out and spray some starter fluid in the plug hole.Replace the spark plug and try to start the engine.It will probably take a few cycles of doing this to get the blower to stay running.
when you put the blower up for a long period, empty the remaining gas out then start the engine and run it till it stops. this gets the remaining gas out of the carb.
Nov 30, 2008 | Garden
Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman) Logo
77 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
