Question about Western Digital Caviar Computers & Internet
No Power Spin-up
This is one of multiple drives. Input voltages are there through part of drive, but not reaching motor and unable to locate technical specs for PC board. Are any diagrams out there?
  • Western Digital Master
  • 9,587 Answers
No diagrams or parts. WD may be able to repair it for you.
Posted on Aug 16, 2017
4 Suggested Answers
SOURCE: power cord
Best Option is to replace with a 12v adapter cord
Posted on Sep 16, 2008
Geekman
  • 32281 Answers
SOURCE: please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Posted on Nov 20, 2009
  • 10406 Answers
SOURCE: I have a 80GB maxtor external hard drive with a
You might have better luck by looking on eBay (and/or Craigs List)
for 'MAXTOR' and '80GB' disk-drives.
Posted on Jun 16, 2010
The 4x4 will not engage on my 2003 ford f150. could it the dash switch?
Does yours have Electronic Shift on the Fly (ESOF) Operation The electronic shift on the fly (ESOF) system is an electronic shift 4x4 system that allows the operator to choose between two different 4x4 modes as well as 2-wheel drive. The operator can switch between 2WD and 4H mode at speeds up to 88 km/h (55 mph). To engage or disengage 4L range, the vehicle speed must be less than 5 km/h (3 mph), the brake pedal depressed, and the transmission must be in NEUTRAL. The transfer case is equipped with an electromagnetic clutch which is located inside the case. This clutch is used to spin up the front driveline when shifting from 2WD to 4H mode at speed. When the control switch on the instrument panel is turned, the generic electronic module (GEM) recognizes that a shift has been requested and activates the electromagnetic clutch and the relays which power the transfer case shift motor. When the shift motor reaches the desired position, as determined by the contact plate position inputs to the GEM, power to the shift relays and motors will be removed. When the transfer case front and rear output shafts are synchronized, the spring loaded lockup collar mechanically engages the mainshaft hub to the drive sprocket. Finally, the front axle collar is engaged and the electromagnetic clutch is deactivated.
After reading this material I would not think it was the switch . Maybe an input problem to the GEM module .
Feature Inputs:
  • 4WD Mode Switch (various resistances; go to Table 1).
  • Contact Plate Position Inputs A, B, C, D (grounded when closed, open circuit when open; go to Table 4).
  • Output Speed Shaft (OSS) Sensor (Sinusoid Signal: 0.7V-20V, 2.2 Hz/mph).
  • Brake Input (battery voltage when brake is depressed, open circuit when not activated).
  • Transmission Range Sensor (grounded when transmission is in NEUTRAL, open circuit otherwise).
  • Start/Clutch Depressed Input (go to Table 3).
  • I would take it and have it check for codes !
Dec 02, 2016 | 2003 Ford F-150
How to fix a has dryer won't spin
Hello Gloria Starling,
The answer is not going to change much... even without the make & model... but it could be said with more conviction...
You have one & only question ... Sadly no make or model came thru with the question...
While this is LARGELY a USA site... GLOBAL products have been able to get satisfaction here as well...
Dryer spinning is LARGELY the function of the drive motor...
or
The DRIVE BELT.
In the USA you need only go to one of the many Parts houses
and input you make & model...
Issuing forth in great abundance will be PARTS PRICES and procedural videos...
The (opinion) worst prices a pushiest sales folks .... come from one of the BETTER on-line technical DATA... domes from SEARS...
If you take my advice & buy your belts/motors & pulleys...
only after getting MULTIPLE ESTIMATES ... You stand little chance of finding how pricy & pushy SEARS agents can be...
Input your details below:
appliancepartspros.com
repairclinic.com
partsselect.com
Search Over 2 1 Million Appliance Parts
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day
returns
http://repairclinic.comartssellect.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Sep 12, 2016 | Dryers
Power is ON but unable to start program
1) You must have the deck belt is WORN, to due the lack of maintenance , however LUBE the deck belt with 100% of silicone or wax
2) Lube the rollers bearing with wd-40
3) Test the drive belt motor and replace if necessary
4) Test the input voltage motor, if there are the motor need repair.see my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 10, 2012 | Exercise & Fitness
I HAVE A NEW KEY I HAVE NO POWER WILL NO COME ON WHEN PLUGED IN
test the fuse and replace, reset the c. breaker and try again
2) test the power cord.
3) test the drive belt motor, for worn, or adjust
4) test the input voltage motor, if there are the motor need repair
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 21, 2012 | Weslo Exercise & Fitness
Unit won't spin
Possible that there is no power to the motor after the cycle is triggered. It can be failure of the drive relay or board , check the output to the motor at the time of the cycle to confirm, if no voltage if present this can be related to the board, if there is voltage check the motor and drive for friction. Check the drive belt.
Sep 03, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
My washer started to fill with water and then beeped and F6 came on the screen.
I am sorry to hear regarding the trouble.Unfortunately, this is not an easy or small fix.
The F-6 is a motor tachometer errorhere is what the units Technical data sheet shows.
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
  • Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
The drive motor is located on the bottom left side .
The MCU(motor control unit) is also on the bottom left side.
If after checking these, if it still does not spin .
You can check the motor windings. if you have a Volt-Ohm meter.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 22, 2011 | Kenmore Elite 45986 Front Load Washer
After moving washer to a new location, it wont run a normal cycle. It starts to fill up with water and then stops and then it starts flashing F-25, 26, or 28. What exactly does this mean and what can we do...
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Nov 25, 2010 | Kenmore HE2 Plus Front Load Washer
Duet washer has F06 code ,What could be my problem
Hi.This will occur when The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Replace failed component.(If the connections between the CCU/MCU/drive motor, are correct, and not severed, thsi will lead to a failed Tachometer, which is located on the motor shaft. The motor will need to be replaced, in this case.)
Oct 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
Lincoln 175hd mig will not feed.
Make sure your roller motor is spinning. If it is, then adjust the rollers tight enough to spin out the wire. If power is available and motor does not spin, check the fuse on the control board. If it is ok, then it is your control board.
May 06, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Computers & Internet Logo
35 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
