Question about RCA Televison & Video
Cant tune channels
WE have bought 3 antennas since yesterday. The original antenna and all of the new antennas still work on our original box TV. However, we cannot tune in all of hte local channels on new TV. WE can only tune in some local channels. We have moved the TV to several positions in several rooms. NOthing works.
  • 50 Answers
It sounds like you need to do a complete installation as if TV were new.
This is done from installation menu
Posted on Feb 14, 2014
57 varieties
  • 1653 Answers
SOURCE: Digital tuning is failing
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
  • 603 Answers
SOURCE: I don't have cable, so I bought a small antenna to
It's all digital now - don't forget.
You need to switch from cabel to antenna first.
Play around with menus - it has to be there. Or just do areset if there.
Posted on Dec 17, 2009
Thompsons196
  • 350 Answers
SOURCE: i have recently bought a
Does it have a built in digital tuner? unplug wait 5 minutes hold power button while you plug it in you should get into a secret menu usd by techs look and see if you have a digital tuner hope that way works for that set
Posted on Jan 27, 2011
bobhifi
  • 635 Answers
SOURCE: New LG 32LD350 - Allowed TV to auto-program
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Posted on Mar 11, 2011
  • 102 Answers
SOURCE: tv saying cant find an antenna.ive pluged in hdmi
You have to go into the input menu and select HDMI as you are on the antenna source at the moment,
Look for "input" or "source" button on your remote control and go to HDMI and press "select" "o.k" or "enter" button. Best of luck.
Posted on May 06, 2011
Testimonial: "spot on.thank u"
Unable to tune into any channels
It's much more likely to be the antenna. How old is the TV? Check whether the antenna connection is loose. Check whether the antenna cabling is all connected. Did anything change just before the TV stopped working, like someone doing work outside? If you're receiving cable TV check the connections to and from the cable box.
Nov 16, 2013 | GPS
How to hook up convertor to analog tv
It would really help to know what brand of converter (set top box) you are installing but I can provide some general information. Be sure to connect everything before applying power. On the rear of the box, you have two types of connectors. If your RCA TV is old, you can connect a cable from the ANTENNA OUT F connector to the antenna F connector on the rear of the TV. Connect an antenna to the ANTENNA IN F connector on the rear of the box. Set the box to send output to channel 3 or 4, whichever is not used in your area. Apply power to the TV and the box and tune the TV to the channel (3 or 4) you selected on the box. If your RCA TV is new enough to have inputs for left and right audio and video, you can connect a 3-conductor RCA cable between the appropriate outputs of the box and the corresponding inputs on your TV. The picture quality will be better the second way. Once you are up and running you can use the channel search feature of the remote for the box to locate HD channels
Feb 13, 2013 | RCA Televison & Video
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
No Signal
Make sure you have a good connection from the antenna to the converter box. Set your TV to channel 3 or 4.
The converter won't improve reception in any way, and it's possible you might need to relocate your antenna or get an exterior antenna hooked up to improve the signal strength.
If you have enough antenna cable, and you're only using rabbit ears, hang them out the window or up on a curtain rod and see if that improves things.
Some people have good luck with the new digital style set-top antennas. I think you'll have best luck, though, with an old roof-top antenna that's set up to feed your converter.
Best of luck to you!
Apr 10, 2009 | Insignia Digital-to-Analog Converter for...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
