Question about Panasonic KX-T7030 Speaker Display Phone White / Refubished
Dialing an ext shows gone home message on my extension
When I use internal dialing, i call an extension and instead of that extension ringing, my disploay shows gone home
4 Suggested Answers
SOURCE: need to store new extension numbers
ghgiuyl,hjkhgkfkm
Posted on Feb 17, 2008
  • 14 Answers
SOURCE: 7453 Display
Without looking up details on versions, I think you may have an early D1232. Look at the plate on lower edge/front and see if there is a number in a circle. If there is no version number, the serial number will tell when the system was made.
Posted on Jul 16, 2008
SOURCE: KX-T7633 Assigning Internal extension buttons
9937273736name and adrise
Posted on Aug 19, 2009
SX-50 Mitel wake up calls won't go through to rooms. Is there a way to reset or fix this?
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
May 18, 2011 | Mitel 9104-001-000 Power Supply SX-50...
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
Mar 16, 2011 | AT&T Lucent MLS-12D Phone
Mitel sx 50.. How to unlock room phone..how to take it off from do not distrub(in room phone)? Thank you so much
Attendant
Oct 13, 2010 | Mitel 9104-001-000 Power Supply SX-50...
Can't access Voice Mail from Message button. Button is lit but pushing it causes another extension to ring. How do I undo this?
You either let the other extension answer, or you cancel the message.
Cancelling is done by dialing 700 your extension and # on the intercom.
It will clear ALL messages. This is if your set is connected to a TD system. If a TDA, then *700 your ext and # works.
Carl
Jun 18, 2010 | Panasonic KX-T7431 Corded Phone
I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
Feb 08, 2010 | Panasonic KX-T7730 Corded Phone
Extension call
You need to page an extension.
To program this on a button:
press feature 00
press the intercom you want to change (EX: ext 10)
press the right intercom and *10
press feature 00
To use, just press the button you just programmed. It will grab intercom and dial *10. Conversly, you can press intercom *10 to do the same.
Aug 05, 2009 | Avaya Corded Phone avaparp18d
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
Nov 12, 2008 | Executone 64 Corded Phone
Oncoming phone calls from internal ext go directly to speakerphone instead of ringing
If this is on just your extension, dial 640 without picking up the handset. The phone should beep twice. If not, hang up the phone and let me know. If this is helpful, please post as such.
Apr 29, 2008 | Vodavi 30-Button XTS Telephone
Phantom station is dialing constantly
ext 54 maybe a voicemail port. There could be a mailbox that is programmed with message notification to the ext. that is ringing.What toshiba system do you have (phone and Voicemail)
Feb 27, 2008 | Toshiba DKT2010SD Phone
Panasonic KX-T7030 Speaker Display Phone White / Refubished Logo
19 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
