Question about Garden
Craftsmant 30in snowblower stops running - Garden
  • Garden Master
  • 2,478 Answers
Remove fuel line from carb. and see if fuel runs out.
Posted on Feb 14, 2014
MTD Mastercraft Snow King Snowblower (1997) electric starter stopped operating today (during a snow storm of course). Any ideas? Thanks. Checked cord - good condition. Power to the chord. David
It was running and stopped while using or it worked one day but not the next?
The Machine stopped running or just the electric starter? If just starter check to see if snow/ice built up around starter button.
Jan 06, 2017 | Garden
Only runs for a short time
Jeff, Try running with cap off for a short time to see if cap vents plugged, probable dirty carburetor.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Snowblower Starts Then Stalls
Tecumseh Carb snowblower cleaning 1 of 2
HOW TO Remove Clean Fixed JET on Snowblower Carburetor
Mar 23, 2016 | Toro 1028OXE Power Max 38663 2-stage...
Free chat line not
Usually the motor's piston burns up. You likely need to replace the motor. Yes, expensive, but probably less than a new snowblower.
Jan 05, 2014 | Toro Garden
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
I have a craftsmant LT2000 and it won't engage the blades
check to see if a belt came off, it would go from bottom engine pulley to deck lever pulley then around blade pulleys on deck. the pulley underneath has to tighten for the belt to run blades, the pulley is either solid to lever or has a cable that moves it make sure cable did not break hope this helps Tim
Mar 13, 2011 | Craftsman Garden
My Swisher snowblower when I engage the forward or reverse gears, it runs then stops then runs then stops. Is there an adustment that needs to be done? This just started today. It was not doing this...
mine does the same took it in they said nothing was wrong now this year the motor went 3 hours on this thing and no compression swisher is junk in my opinion
Jan 11, 2011 | Swisher Garden
I can't find my manual for a Tecumsah LawnBoy 824E 8.0HP Electric start snowblower. It starts fine, but does not continue running. I just filled the tank with new gas. It ran to run about 25 feet and then...
Hi
Sounds like a clogged carb which is a common problem for snowblowers due to they set around more then they get used and gas turns stale and clogs carb. Most of the times the problem is in the bolt that holds the carb bowl on it should have 2 or 3 small holes in it. Check that the holes are all open and clean if this does not help you will need to remove and clean whole carb.
Sam
Please vote
Jan 07, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
I have a snowblower that will only start if I remove sparkplug
GO TO ADVANCE AUTO OR YOUR AUTO STORE AND GET A FUEL ADDITIVE CALLED SEA-FOAM ADD TO GAS AS DIRECTED , YOU WILL POSSIBLY BE AMAZED
Dec 21, 2008 | Karcher 2500 PSI Pressure Washer
Snowblower runs then quits
check to see if gas cap vent is clear . its the little pin hole at the top of cap . if not clear it will cause a vacuum and stop the flow of gas ... good luck
Dec 19, 2008 | Mastercraft Garden
I have a troy built snowblower that has sat for 7 years.
hi roaddoctor86; I suspect that your carb is the source of your problem in the fuel system. I always drain the fuel in my 2 cycle and even 4 cycle engines and then start them and run them dry, before I put them up for the winter/. I would suggest you drain the tank or at least take most of the gas out and then add a can of gas treatment/solvent and see if that helps. Something like Heet I think is one product.
Hope this helps good Luck Loriongh ps Please leave a rating if appropriate Thanks
Nov 20, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
