Question about Whirlpool GFG474LVS 30" Freestanding Gas Range with 5.0 cu. ft. Capacity Oven, Full Width Cooktop Grates, Integrated Griddle and Storage Drawer
Oven will not stay on
Oven lights but will not stay on.
How do i replace halogan light
https://www.youtube.com/watch?v=gTSNUQmSzTw
Aug 12, 2016 | Sharper Image The 8127SI Super Wave Oven...
What caused it to stop working?
check with the manufacturer on their website .
Jan 10, 2016 | Sharper Image The 8127SI Super Wave Oven...
Power Surge Electrolux double oven EI30EW45JS, now producing F11 code, installed new board, how to reset to see if problem is fixed?
Good Morning Jennifer Lynch, thanks for your post!
I see you have replaced the control board on your Electrolux wall oven and it is displaying an "F11" error code. "F11" stands for a shorted keypad, since you have replaced the board I would recommend resetting your wall oven. You can reset your wall oven by flipping the household circuit breaker off for ten minutes. If you need further assistance please feel free to reconnect. I hope this is helpful. -Matt
Oct 13, 2014 | Electrolux EI30EW45JS | 30" Double Wall...
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
The storage drawer is off track (seems to have dropped down). It is not easily removed from the track and the manual does not show how to remove it. Any suggestions are appreciated.
In some cases I have had to pull the oven completely out and either access it from the back or lay the oven down on its back to see where the problem is at, but in most cases it is usually a simple fix once you can get to where the actual track is located.
Hope this helps. Make sure once it is back that you inspect the track and the wheels on the drawer t make sure no metal was bent, if it was and you cant bend back most local appliance suppliers have the parts you would need to repair it.
Oct 13, 2013 | Whirlpool Gold GFE461LVB 30" Freestanding...
Oven won't heat
I believe you popped your breaker at the box. If it does not reset then you have to replace the breaker itself.
Oct 07, 2012 | Whirlpool RBD307PVS 30 Double Electric...
Power light not coming staying on...
pull the cells out and run the filter without them. If the light stays solid then you most likely have a simple short in one of the cells. Install one cell at a time, push it all the way back, close the door, turn on the fan. IF the light stays solid, that cell is fine. If the light flickers or goes out, the most common cause is a bent fin.
Look at the cells and see if any cells are touching or are too close, this will cause your problem.. Simply bend the cells to get even spacing and you should be ok.
Jul 15, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Whirlpool GFG474LVS 30" Freestanding Gas Range with 5.0 cu. ft. Capacity Oven, Full Width Cooktop Grates, Integrated Griddle and Storage Drawer Logo
21 people viewed this question
Top Whirlpool Air Purifiers Experts
mike cooper
ray gallant
Jerry Kramer
Jerry Kramer
Are you a Whirlpool Air Purifier Expert? Answer questions, earn points and help others
