Question about Waterpik SinuSense Soothing Saline Easy-Pour Packs, 120 ea
I need to buy. What is the cost? - Waterpik SinuSense Soothing Saline Easy-Pour Packs, 120 ea
No sound on 3 keys of the piano.
if it only three keys only you may want to find out is it worth fixing the 3 keys or is it cheaper to buy a new one. the cost of labor, cost for parts need to fix issue, and down the road so a week, month or year it happens again 1-2 keys go out, way the cost verses the new unit plus a warranty to new unit, it is better to buy a new one these days cheaper to buy than repair the cost and parts and labor is so high.
i hope this helps
thank you rod
PS call around instruments store, piano and organ shops, ask if they repair and is it worth repairing they will be honest with you
Mar 04, 2015 | Yamaha Dgx300 Electronic Keyboard
How do i get replacement parts?
What kind of part?????????????????? Need make/model of fan.
Aug 17, 2014 | Dryers
How does advertising increase avarege costs?
If you are paying for the advertisements, those payments have to be included in your "costs" (you have to buy the inventory, you need to buy shelves to hold your inventory, you have to rent commercial-space to hold the shelves, you need to pay clerks to help at your check-out desk) of your store). Advertising costs money, and you hope that advertisements will increase sales, to make money to more than offset the costs of your advertisements.
May 20, 2014 | Computers & Internet
I have a Samsung Plano (39 Cm, Model No.CZ15K5M JOX/XTL) its Picture Tube has gone and need to be replaced, Please suggest how & from where I can get it and what will be the minimum cost.
In the present situation it is not advice able to BUY a new picture tube and replace as the cost factor is very important and also since the CRT type sets are phasing out.
Please try and see if you can source a second hand tube for a nominal cost, or from a scrapped set. This might be better than to buy a new one as it might be better to buy a new set with warranty.
Please check the cost and decide.
Jul 22, 2011 | Televison & Video
Front wheel bearings need replacement. At what cost?
wheel bearings are'nt that expensive. i would buy 4 bearings and replace all four on the truck. the cost of two or four labour should be the same. a mechanic should have it done for you. buy the bearings youself and let the mechanic do it for you. good luck
May 06, 2010 | 1999 GMC Suburban
Lost adapter
Try to avoid buying a adapter as the compatible ones do not wirk properly and if you try to buy a original one then the cost will very instead of buying a new router will be cost effective.
Feb 12, 2010 | Belkin (F5D5231-4) Router
What is toner resetting by software or hardware?
A hardware module is used to reset clp 315 permanently after that you can use refill toner forver. www.nakshatraworld.com
Jan 25, 2010 | Samsung CLP 315 Laser Printer
I have a 1991 dodge colt vista they said i need pistons or rebuild the motor is it worth fixing it or should i sell it to the ecolgy wreck please give me a answer quick and how much will it cost me to fix...
A professional engine rebuild can cost anywhere from $500 to $1500 or more, depending on what needs to be replaced/serviced.
If you plan on doing the work yourself, you could get away with less than $200.
Whether or not it's "worth it" to fix the car or replace it, is relative. You have to remember to factor in the cost of purchasing/fixing a new car versus the one you're driving now.
Vehicle resale value should not be considered in whether or not it's "worth it" to repair a vehicle, unless you intend to repair it before selling it. The primary consideration should be the cost of fixing it versus the costs you will incur utilizing other options, such as buying new, buying used with payments, buying used outright, etc.
Keep in mind that all vehicles eventually need service, and a more expensive vehicle tends to need more expensive service procedures.
Dec 29, 2009 | 1991 Dodge Colt
Cost details
Costs are between $250 and $350 at the moment, depending on where you buy. If you don't buy over internet, the price depends on your location and the shop where you're buying.
Apr 23, 2008 | Nokia 6233 Cellular Phone
Lost dough blade
I think that it dosnt cost a lot to buy on e but It might be hard to replace it.If I where you I would buy a new blade.
Dec 29, 2007 | Kitchen Appliances - Others
Waterpik SinuSense Soothing Saline Easy-Pour Packs, 120 ea Logo
316 people viewed this question
Top Waterpik Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Waterpik Medical Expert? Answer questions, earn points and help others
