Question about Honeywell MS9520 Voyager Handheld Scanner w PS2 Cable ATXT Adapter + Stand Handheld Barcode Scanner
MS9520 not reading bar code
    Problem Solver:
  • 11 Answers
Please Reset the Scanner. Manual has the Reset Bar Code
Posted on Mar 30, 2014
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
I want scan barcode 39. Hou can i program mine ms9520 voyager scanner. Thank you
http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf
That is a link to the PDF help file for the MS9520. It has barcodes inside that you scan with your scanner to enable/disable certain features. It looks like you should be able to enable Code 39 barcodes by scanning the barcode found on page 2-2 (actually on page 10).
May 26, 2011 | Honeywell MS9520
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
We recently received another 9520 from Honeywell to replace a faulty one. For the non-tekkie, how do I configure it for use with library scanning for books?
Bar Codes The MS7120 can be configured by scanning the bar codes located in the MetroSelect® Single-Line Configuration Guide. This manual is available for download at http://www.honeywellaidc.com/site.aspx/na/en/product_center/product_support/?category=5&product=297
Please let me know if you need further assistance
Kim Ganoe 800.933.2839 x251.
Mar 23, 2010 | Microsoft Metrologic MS9520 Voyager...
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Incorrect Reading
Try experimenting with the different inter-scan code delays. You can find the programming barcodes in your manual.
Aug 20, 2008 | Metrologic Instruments Voyager MS9520...
Ms9520
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
Metrologic MS9520
You can reset back to original setting using your manual. If you are using cash register you need to look for the right settings in order the scanner will working.
Rate me SOLVED
Nov 21, 2007 | Metrologic Instruments 9520 Voyager
My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Honeywell MS9520 Voyager Handheld Scanner w PS2 Cable ATXT Adapter + Stand Handheld Barcode Scanner Logo
232 people viewed this question
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
