Question about Husqvarna Viking 1
Embroidery unit device disconnected
Machine displays message "Device Disconnected"
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like cable has become disconnected inside machine or emb unit. Have it checked by authorized Viking Dealer. Check website http://www.husqvarnaviking.com/us for nearest Viking dealer.
Posted on Oct 16, 2014
5 Suggested Answers
dupina
  • 110 Answers
SOURCE: Will a Husqvarna #1 Plus embroidery unit work on a Husqvarna Rose machine?
I am sorry to inform you that Husqvarna # 1 embroidery unit does not fit onto the Rose machine. The terminals on the Rose is upright, while on the H # 1 it is flat. If you want to do embroidery on the Rose, you will have to purchase the embroidery unit.
Sad but true
Posted on Jan 22, 2008
SOURCE: Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Posted on Jan 10, 2009
  • 152 Answers
SOURCE: With memory stick in Designer SE machine USB port,
Notice if this problem ever happens with the memory sitck that came with your machine. If it does then it may be the outlet you plug your stick into. Look at the outlet, does it looked damaged in any way?
Some USB sticks now come with programs on them with could be causing a conflict in your machine.
I would look at the files on your original stick through windows explorer and see if there are program type files that you could copy to other sticks that may help them communicate with the machine better.
Posted on Oct 10, 2009
  • 201 Answers
SOURCE: embroidery says device not connected
Where are these messages appearing? In your computer embroidery software or on the machine's screen?
Posted on Aug 11, 2010
My sewing machine brother SE-400 does not work the LCD display say the security device is activated. How I do to unlock
remove the embroidery unit and check the bobbin case. Usually, there is some thread tangled down there.
Aug 14, 2014 | Sewing Machines
Embroidery unit of Designer se
Feb 14, 2014 | Husqvarna Designer I
Device disconnected message
Feb 14, 2014 | Husqvarna Viking 1
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
I have a Brother Ult 2001 and I was right in the middle of monogramming a towel using the large frame when I ran out of bobbin. I took the frame out and changed the bobbin and when I returned the frame to...
My friend just had this problem a couple weeks ago. Here's what we did. We cleaned the bobbin case with canned air lightly. We turned the machine off and disconnected the embroidery unit. Turned the machine on without the embroidery unit and ran a straight stitch. Then we turned it off, reattached the embroidery unit and touched another design of a different size. Attached the hoop without fabric just to see if it would "take it" and it did so we put the right size hoop back on and selected the design we were on originally and it worked. Some times these machines are just "touchy" and don't let you do something and after a "rest" they're ok. I hope this works for you.
Aug 24, 2010 | Brother Sewing Machines
Embroidery says device not connected
Jul 18, 2010 | Husqvarna Designer I
DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
but is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Sep 10, 2008 | Brother LS-2125 Mechanical Sewing Machine
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Programing
program-controlled sewing or embroidery machine comprising a stitch-forming device (2), an integrated microcomputer (4), at least one memory (16, 17) and at least one data interface (5), as well as a keyboard (12) and a display (11) for entering and monitoring or checking values for program control. To retrieve sewing or embroidery pattern data from a remote computer (mailbox) in a simple manner, the data interface (5) of the sewing or embroidery machine (1) is able to be connected directly to the mailbox (10) of a central computer (9) via a data transmission connection (7) via a corresponding modem (6), and the structural units which are necessary for communication with the mailbox (10), such as display (11), keyboard (12) and memory (16, 17) are disposed in the sewing or embroidery machine (1) itself, with the functional processes necessary for communication with the mailbox (10) being able to be controlled and monitored by the microcomputer (4) necessary for controlling the program of the sewing or embroidery machine. The invention further relates to a method of operating program-controlled sewing or embroidery machines.
Mar 17, 2008 | Elna Quilter's Dream 6003Q
Sewing Machines Logo
48 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
