Question about ZVOX Televison & Video
Cannot get sound from Samsung TV to Zvox V220
I have a ZVOX 580 soundbar. Using the digital optic cable I have no sound. I have sound through RCA cables. Can you help?
They to check the menu of the TV is there is any option to activate the Digital out or is there is any setting which allow you make a selection between internal speaker or external speaker. if its there the make the setting as external speaker .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 15, 2016 | ZVOX ZBase 580
I need setup code for my zvox sound bar for a Comcast remote?
I am the same boat. Just bought a bigger tv and my zvox doesNOT work now
Jan 26, 2015 | ZVOX 4002201 Audio Z-Base 220 Low-Profile...
ZVOX v-series 320 no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 11, 2014 | Televison & Video
THE SOUND WORKS ON TV BUT THE REMOTE CONTROL DOES NOTHING.
Batteries could be bad, circuit board in the remote may be shot and try cleaning the infrared light on the remote and TV. If none of that works order a new remote or get an all in one, just make sure it has the programmable code for your TV
Dec 10, 2014 | ZVOX ZBase 580
Zvox remote not working
Place the unit in learn mode: http://www.zvoxaudio.com/mas_assets/theme/zvoxnew/documents/ZVOX580_LearnRemote_Guide.pdf
Nov 08, 2013 | ZVOX ZBase 580
No sound
Try to rule the set out with a DVD etc connected directly to the set. Also if using a box of some type to the receiver--unplug it and the receiver and power back to let them reboot---short of that most shops can check for a small or no fee the receiver to see if it is the issue.
Aug 28, 2012 | ZVOX Z-Base V220 Soundbar Home-Theater...
No sound
What type of cable are you using to connect your ZVOX system? Are you connecting your system directly to your TV? In order to solve your issue as quickly as possible I would encourage you to call our toll free number.
(866) 367-9869 We can troubleshoot over the phone and get you up and running in no time. Thanks.
- Joe
ZVOX Audio - Great Sound, Made Simple
www.zvoxaudio.com
866-367-9869
May 23, 2012 | ZVOX ZBase 580
What could be wrong if i have everything hooked up right i have it connected to the back of my directv box with audio coming out and going into input 1 on zvox box and is the blue light suppose to always...
1. Make sure it's connect to "Audio Out" on your DirecTV box.
2. Yes, the blue light should be on while unit is on an received a signal.
3. Check a second set of audio cables, just to be sure.
4. Toggle the Auto On/Off button on the ZVOX remote.
5. Make sure you've turned up the volume via the ZVOX remote.
If all these fail, contact us at zvoxaudio.com.
Tom
Jan 30, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
Motorola V220 camera
fuck you !!!! motorola sucks!!!!!!!!! samsung rules!!!!!!!!!!!!
Dec 21, 2007 | Motorola Mobility V220
Televison & Video Logo
55 people viewed this question
Top ZVOX Televison & Video Experts
Tom Chichester
Are you a ZVOX Televison and Video Expert? Answer questions, earn points and help others
