Question about Husqvarna Designer I
Embroidery unit of Designer se
Device disconnected message
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Sounds like cable has become disconnected inside machine or emb unit. Have it checked by authorized Viking Dealer. Check website http://www.husqvarnaviking.com/us for nearest Viking dealer.
Posted on Oct 16, 2014
dupina
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
SOURCE: designer 1 embroidery problem
If the machine is reading the file to not be found it is probably that the designs are on the floppy but the person sending did not read them to the floppy right. they should have been read thru the softwear.
Posted on Jan 19, 2008
SOURCE: viking designer se limited
You can find this information by touching the configuration icon (this looks like pliers). The item that shows you how many sewing hours is called Timer. You should know that this can be reset to 0 by anyone.
Posted on Dec 29, 2008
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
  • 371 Answers
SOURCE: DESIGNER SE breaking needles
Sounds like the needle to hook gap needs to be adjusted, i.e. the needle is striking the hook when in the lower position. As the needle becomes dull, it probably bends slightly causing more contact and hence breaking. I would try another dealer if you think that might help., You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
How do I take off the arm
On the embroidery unit or regular unit? I have a designer
both comes off easy
Jan 28, 2015 | Husqvarna Viking 1
Embroidery unit device disconnected
Feb 14, 2014 | Husqvarna Viking 1
Embroidery Arm is not moving right/left
Check to notice if when the embroidery arm is installed and you turn the power on does the embroidery unit move as it calibrates the stepper motors. If not I would first check the plug where the machine and embroidery unit attach. If this looks ok and is not out of place it could be a cable, or the main circuit board. Both of those are for your dealer to repair.
Feb 08, 2014 | Husqvarna Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Viking designer se screen is stuck in welcome screen when turned on. update did not help me! my steps: 1turn on Designer SE le and connect to computer. 2install Designer SE 3D embroidery Software...
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
Dec 04, 2010 | Husqvarna Designer I
Embroidery says device not connected
Where are these messages appearing? In your computer embroidery software or on the machine's screen?
Jul 18, 2010 | Husqvarna Designer I
Can't update my new husqvarna diamond embroidery machine
Thanks for the response. The problem turned out to be my fault. I had my Diamond connected to my computer when I tried to install the drivers. As soon as I disconnected it, the drivers all installed and everything is fine.
Nov 24, 2008 | Husqvarna Designer I
Designer 1 embroidery problem
Dec 28, 2007 | Husqvarna Viking 1
Sewing Machines Logo
96 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
