Question about Dayton Gas Furnace Heater
Dayton fuel trimmer 3e438a fan limit control
LOOKING FOR A FAN LIMIT CONTROL FOR A 3E438A /H550-94941 DAYTON FUEL TRIMMER UNIT.
2 Suggested Answers
piney66
SOURCE: furnace fan runs costantly
Check to see if fan setting is summer or winter.
Posted on Feb 05, 2012
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
My Dayton 110,000 btu kerosene torpedo heater... The fan kicks on for a couple secs then kicks off it seems as it's not getting any fuel what should I do
Could be the Flame out sensor cutting the power to the electrics and therefore the forced air fan. It forces the heater to shut off should the flame extinguish. It might also be the temperature limit control which also turns the heater off if the internal temperature rises to an unsafe level. If either of these two possibilities the unit may need a service.
Dec 09, 2014 | Heating & Cooling
Furnace fan runs costantly
Feb 05, 2012 | Dayton Gas Furnace Heater
Dayton_furnace I have a dayton furnace the blow and burners kick on and run fine, brings the house up to the right temp the burnes shurt down but the fan moter never stops blowing. what is wrong ?
Hello, if you are referring to,the blower motor then most likely the relay on tne integrated contol board is malfunctioning. Unfortunatly the whole board must be replaced in this case.
Nov 09, 2011 | Dayton Heating & Cooling
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
heatman101
Feb 02, 2011 | Dayton Gas Furnace Heater
I have a dayton fuel trimmer furnace model # 3E438A and the problem is that upon ignition to the furnace the unit runs and after about 3 minutes the units inducer fan shuts off and the flames stays on....
It sounds to me like your draft motor is probably shuttimg off on thermal overload. They will get to hot and shut down until the motor cools down then run again.But by that time it's caused other trouble so I think you need to replace the motor first and then see what other problems it has caused.I hope this helps you and thanks.
Jan 10, 2011 | Heating & Cooling
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I was wondering if the Dayton fuel trimmer model# 3E369B can be placed on blocks in the floor of my garage
Yes, it can be set on concrete blocks or anything non-flammable.
Also make sure that you do not run it if you are working with flammable gases or materials. I don't believe that that heater is sealed combustion.
Make sure also that you have correct venting so you don't wake up dead...
If you can take good precaution then go for it...
Heatman101
Jan 14, 2010 | Dayton Gas Furnace Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
