Question about ILuv IMM157BLK VibroBlue Bluetooth Wireless Speaker For Bluetooth-Enabled Devices
How to radio preset - ILuv IMM157BLK VibroBlue Bluetooth Wireless Speaker For Bluetooth-Enabled Devices
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
What proceedure to apply radio code
  • When the radio displays CODE, you may enter the code using the preset radio station buttons
  • For instance, my number is 1615, so when I get the CODE on the radio's display, I press the radio preset button 1, then the radio preset button 6, then the radio preset button 1, then the radio preset button 5.
  • If your radio says OFF, leave the ignition on in the first position for 2 1/2 to 3 hours in order for it to display CODE. In certain models you can clear the OFF state by pulling the fuse for the radio (#7 in my car). That's a bit simpler than leaving the ignition in the first position for a couple of hours - particularly if you don't have a garage.
Jan 04, 2011 | 1998 Volvo S70
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
How do I unlock my 1996 accord anti-theft radio - I have the code. thx
first do you have 6 button presets and is your code also 6 digits.then turn radio on and put in the 6 digit code.but if your radio has 4 buttons then we need a diff way to install.for example code may be 1246. you turn radio on and go to first button preset and hit it once for 1.now go to second preset and hit the preset two times for 2 of the code and go to the next one which is 4.go to preset three and tap the preset 4 times and finish with 6 of code and radio will make sound and select your radio stations.
Aug 18, 2009 | 1996 Honda Accord
Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Jan 08, 2009 | Bose Wave Radio
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Sep 11, 2007 | Timex (T307S) Clock Radio
ILuv IMM157BLK VibroBlue Bluetooth Wireless Speaker For Bluetooth-Enabled Devices Logo
65 people viewed this question
Top ILuv Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an ILuv Audio Player and Recorder Expert? Answer questions, earn points and help others
