Question about Samsung Dvd-e360 Dvd Player With Usb Input
How to adjust the sound on a samsung e 360 dvd player
I have a Samsung 3D tv and Samsung 3D DVD player, when I listen to a DVD the volume seems to get really loud at point during movies especially action scenes is there a fix for this?
Set AVL [Automatic Volume Leveler] function with DVD player; set to 'ON'. Refer its user manual to get more details about this adjustment. The procedure will be different for model to model.
Nov 30, 2014 | Samsung Televison & Video
Digital In on Samsung HT-Z310 no sound
Optical into your XBOX 360? If there is a connector that you are using to convert it, I was start by replacing that.
Jun 04, 2010 | Samsung HT-Z310T Theater System
Happy owner of Pioneer DV 360. However it can only produce a black/white screen also without DVD inside. . Cables checked ok Thanks for your assistance Karsten Denmark
The problem was the TV ( Samsung CB 5073 T). One or more connections on the AV plug in the TV had disconnected from the soldering and was repaired. The DVD was fine all the time.
Thanks again for your assistance
Karsten Denmark
zodiac@city.dk
Oct 05, 2009 | Pioneer DV-360-S DVD Player
Samsung DVD HR735 doesn't recognise DVDs
It sounds like the laser in the DVD player is getting weak or has alignment problems. If the DVD that did not play in the samsung but played in others. I would tend to think its not alignment since you mentioned that it's been repaired before. Chances are the laser is weak but still within spec in order to prevent replacement. When My dvd players start to go they will generally stop recognizing burned media and thats your clue to replace it. They are very inexpensive to replace nowadays and have almost become disposable items. Probably not what you wanted to hear but it sounds like's like this player wasnt made very well.
Jul 13, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Sumsung DVD-V2000
This unit needs its tracking circuits aligned, starting with the mechanical adjustments of the transport....accordianman
Sep 11, 2008 | Samsung DVD-V2000 DVD Player/VCR
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
Samsung dvd recorder DVD-R121, no sound(very faint) or picture (incl onscreen graphics)accepting dvds and is playing them according to lcd counter display
adjust your dvd by using your remote control..adjust the volume control,and set them through menu,if not working your audio ic is deffective.
May 13, 2008 | Televison & Video
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Dvd no picture just sound
When you say No picture?? s the Picture all black Like theres no video? Try checking the video input on the tv or the cables from the player. If the inputs and cables are bad then theres a poroblem in the video processor in the dvd player and the only way to vix that would be to get a schematic diagram and a scope and trace out the video and see where it disapears. Good Luck
Apr 13, 2006 | Pioneer DV-360-S DVD Player
Samsung Dvd-e360 Dvd Player With Usb Input Logo
20 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
