So when i try to power it on i can hear the fan start but not the screen only the caps lock key back light begins to blink
SOURCE: E1705 Wont power on, indicator lights blink for few seconds
Kinldy folloow the steps given , in the following link to pin point the exact cause of failure. I suspect the motherboard has gone bad and it would require a replacement.
http://tinyurl.com/65uofc
Do let me know if you need furthur help
Thanks
Proton
SOURCE: My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
SOURCE: screen black but led lights on hp g71
It may be a hardware error. Call HP and see about your warranty.
A lot of HP's new laptops have hardware defects, which could happen at any time from the day you buy it. Have it sent in and have it repaired for free.
SOURCE: My HP Pavilion dv5-1125nr entertainment PC
Try hooking the laptop to a desktop monitor. This will verify what is failing. If all works, then you have a bad LCD screen. If you get the same problem, you have a motherboard problem which is probably not worth fixing.
SOURCE: HP G61 NOTEBOOK PC BIOS
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
