Question about Datacard SP35 Printer
PR-01738 data card - Datacard SP35 Printer
My I phone 4 WONT LOAD ANY WEB PAGES PR CONNECT TO INTERNET
Hi Zeisly,
There are two ways to go online on your phone:
1. Via GPRS/HSDPA - Your network operator
Not sure which operator you are with, but you need a working SIM card with a data plan as well as the correct APN settings on your phone to tell the phone how to connect to the operator's internet port.
2. Via Wifi, your own at home or public hotspot
For this your phone will need to have wifi, enabled, and set up with the wifi password entered correctly.
The phone should see which is working and use the appropriate connection to connect you to the internet.
Hope this helps.
Nov 15, 2014 | Cell Phones
How to recover tally data from formatted hdd ?
you would have to purchase data recovery software to perform this action. It can not be done with out that software. Once it is formatted with NTFS, it can not be undone because it basically wipes the hard drive the specs of when you purchased it brand new.
Jun 05, 2014 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
Lucky draw coding
You need two things:
1. JSP/Servlet knowledge.
2. SQL Programming basics
1. Create your PR jsp page which contain a form with method post and action to a servlet that will handle the insertion of the data to a database table i would add winners table containing ID, Frkey, thenumber
2. A servlet that will generate the number and cross check with those who guessed right and update the winners table with that data.
3. A servlet that will do an inner join with the pr and winners tables to display the results.
Good luck
Apr 05, 2010 | Sun Java Programming Language (cdj-275)
PR ERROR
There is nothing to correct: the calculator is merely informing you that the continuous memory has been reinitialized. In other words all your data has been erased. Press any key to erase message.
You should expect this kind of errors once in while, especially if batteries have been depleted for a while or have been replaced.
Hope it helps.
Thank you for rating the solution.
Dec 07, 2009 | HP 12c Calculator
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Aircell pocket internet on my nokia 6233 give me setting on my poocket or computer setting also
Connection name: Pocket Internet
Data bearer: GPRS or packet data
Access point:aircelwap.pr
Proxy address: 192.168.35.201
Port: 8081
Leave the other connection as default
Please rate this solution
Rnj VINODKUMAR
Oct 20, 2009 | Nokia 6233 Cellular Phone
Downloading photos to PC - my Compaq/Xp Pr won't
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Mar 10, 2009 | Konaki DV505 Digital Camera
I wish to know for which part of the country does the code 01738 belongs to ???
can I connect a Sprint Sanyo phone with a motorla blue tooth headset
Apr 22, 2008 | Lands Phones
Datacard SP35 Printer Logo
23 people viewed this question
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
james laughton
james laughton
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
