Question about Philips Televison & Video
Red x appears when trying to link tv with computer
To a Macbook Pro
  • 4 Answers
Where is the red "x"? On the Mac? On your TV? What kind of cable are you using?
Posted on Apr 24, 2014
3 Suggested Answers
SOURCE: I am trying to connect my MacBook Pro to my TV
You have to go to System Preferences, Display and then choose display, arrangement and then check the box mirror images. If you have done that, and it still doesn't work, then I'm not sure what else to do! I hope that helps.
Posted on Jun 01, 2010
cgirald2
SOURCE: no hdmi sound from macbook pro to toshiba 40E210U
I was having this exact problem. You have to go to the "Audio MIDI setup" icon in the utilities folder. plugin your mac to the HDMI and TV and it should show up on the menu bar on the left as "HDMI"- then click it. then you have to click on the "format" drop down menu and change it to either 48000.0Hz or less. Make sure that the volume is down on your TV bc I almost gave myself a heart attack when I clicked it. Apparently the TV HDMI input is not compatible with the default on the Mac. Hope this helps!
Posted on Jun 12, 2012
How to transfer Kindle library from iPad to my MacBook Pro
When you register your Kindle app on your MacBook Pro with Amazon, all your books should appear in your library.
Feb 24, 2015 | Apple MacBook Pro Laptop Computer with...
How to change battery on macbook pro
For most recent macbook pro's all you will need a small phillips head screwdriver to take the bottom of the casing off and unscrew the battery. Below is a link to a simple, quick instructional video: How To Replace the Battery in Macbook Pro 13 Unibody
Sep 08, 2014 | Apple MacBook Pro Laptop Computer with...
How can i connect my macbook pro to my LG 50PJ350 to play movies?
I would try an s-video connection from computer to tv, it just might bypass all that copy right stuff that may be giving you problems
Jul 28, 2013 | LG 50PJ350 50 HDTVReady Plasma TV
Apr 03, 2010 | Sharp AQUOS LC-20S5U 20 in. EDTV-Ready LCD...
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
How do I get TV to recognize audio from laptop....
Try the following:
1. Select System Preferences from the Apple Menu.
2. Select the Sound icon.
3. Click the Output tab at the top of the window
4. Highlight the option that is not the Internal Speakers.
5. Make sure the Output Volume is not set low and that the Mute checkbox is unchecked.
6. Close the Sound window. (via Red Radio Button, Top/Left of window).
Try it again and see if you get sound this time.
I hope this helps. Regards,
Feb 05, 2010 | Apple MacBook Pro Laptop Computer with...
Airport card disconnected
There is no Macbook pro G4 (macbook pro are using intel chips) please clarify
Jan 19, 2010 | Apple PowerBook G4 Mac Notebook
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Computer and Speakers
HERE is a link to the Z-540 manual. It should help. Connect the green plug from the audio input cable to the "line out" jack on your TV. Do NOT use the black or orange plugs. WIth a 2 channel card like your TV's you will not get sound from the rear speakers unless you enable matrix mode through the remote.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 05, 2008 | Logitech X-540 Multimedia Surround Sound...
Televison & Video Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
