Question about LG WM2140CW Washer
TE error code
What does this mean and what do I do to fix the issue?
4 Suggested Answers
  • 15 Answers
SOURCE: code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Posted on Jul 21, 2010
  • 106 Answers
SOURCE: My washer has a te
It means the THERMISTOR is faulty and most likely needs to be replaced. It's about a 7-10 dollar part, plus shipping. The problem is, you'll need to take the machine apart to replace. The best thing to do, is contact a professional for repairs.
Posted on Mar 07, 2011
  • 3 Answers
SOURCE: Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Posted on May 04, 2012
How can I fix this?
Hello. There is an LE error that means "fill error". There is also a "tE" error that means "sump thermistor failure". You are probably getting the tE error--the thermistor is located at the bottom front of the washer tub in the center. If water is leaking from the bellow(the rubber part that seals tightly against the door), it might be spilling down onto the thermistor wires, shorting it out. With any leak, this will be an INVOLVED repair. My suggestion is to call for service--to reach anything in the front of the washer internally, the front panel must be removed--this is complex, and must be done carefully, especially if the bellow is leaking and needs to be replaced. I hope I helped you!
Aug 21, 2015 | Maytag MAH2400A Front Load Washer
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
My washer has a te error code, lost the owners manual, what does the te code mean and how do we fix it?
Mar 06, 2011 | LG WM-2277HW Front Load Washer
I have an washe - LG Tromm model # WM2277HB - and I am getting the error code te. What part do i need to repair this problem?
'te' on LG's normally means Temperature Error- a heating element problem. Sorry but I suggest you need to call out a service engineer to attend to it ;-0(
Good luck,
John C
Mar 05, 2011 | Washing Machines
Jan 05, 2011 | LG WM2487H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Apr 27, 2009 | LG WM2277H Front Load Washer
TE Code flashing what do this mean?
Error code tE is THERMAL ERROR. It is possible that the thermister has failed, but the most common cause is inlet water being hotter than 149 degrees (F) The optimal inlet temperature is 120 degrees minimum.
Always check that before you suspect hardware failure.
What did you find to be the problem? Thank for a reply.
Dec 23, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Wm2032hw
tE error code means the thermistor has failed.  That part is located in the front of the drum next to the heater element.
Aug 08, 2007 | LG WM-2032H Front Load Washer
LG WM2140CW Washer Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
