Question about GE JTP45 Electric Double Oven
How to replace lor element in the upper oven on a JKP45W0W1WW
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: replace upper grill element in a old GE wall oven
Replaced selector switch...problem solved.
Posted on Dec 05, 2008
scottowa
  • 87 Answers
SOURCE: Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Posted on Mar 04, 2009
dmftrucker
  • 1922 Answers
SOURCE: install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Posted on Sep 13, 2009
Daniel S
  • 4323 Answers
SOURCE: My GE double electric oven
Hi
If the error code still appears, then the problem is likely in the control module (circuit board) behind the keypad and clock. You'll need to remove the bezel to get behind the control panel. Remove the screws & lift the panel up about a half inch and pivot it forward toward you. The circuit board you can now see is the Control module. Check for the black square shaped components on this board, they may be burnt or the connection might be loose. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 11, 2010
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
The upper oven in my double wall oven it does not heat up
Probably a bad upper element in your oven (assuming it's an electric oven) IF you want a video of how to fix it try going to youtube and searching for "replacing upper oven element" and watch some of the videos that come up. Try to find one that looks like your oven.
Oct 21, 2014 | Ovens
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Apr 26, 2009 | Frigidaire FEB27T5D Electric Double Oven
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
GE JTP45 Electric Double Oven Logo
43 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
