Question about Canon F-502 Calculator
My canon F-502 doesnt have fraction button - Canon F-502 Calculator
Cannot find the shift key
The shift key is the top Left button (it as no markings on it), to the left of the ENG button
Mar 04, 2014 | Canon F-502 Calculator
Where is mod on calculator
Sorry to disappoint you but this calculator does not perform modulo calculations. However you can use the fraction key [a b/c] to enter the numerator and denominator. If the result is given as an improper fraction a b/c, then a mod c=b.
If the result is given as an improper fraction (that would be you input) press [SHIFT][a b/c] to convert it.
On the display integer part, the numerator of the fraction part and its denominator are separated by a symbol as seen on the screen capture below.
Jan 24, 2014 | Canon F-502 Calculator
On my Canon F502G, my a b/c button does not work from decimals to fractions. It will only go fractions to decimals. Is there something I can do to get it going?
If you convert a fraction to decimal and then just after do the opposite it will convert from decimal to fraction. But if you do some other calculations in between it may not do it.
Oct 30, 2013 | Canon F-502 Calculator
Decimal to fraction
Look for a key that is marked [a b/c]. If that key exists on your calculator (I cannot find a specific manual) its second function is marked as [b/c] or [d/c].
To enter a mixed number you enter the integer, press [at b/c], enter the numerator of the fraction part, press [a b/c], then enter the denominator followed by the [=] sign.
To convert from decimal to fraction and back, you press the fraction key or its shifted key.
Sep 30, 2013 | Canon F-502 Calculator
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
TV
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
Jul 03, 2010 | Philips Televison & Video
I have a universal remote control which is philip and tv set which is also philip but I dont know the code to be used.
DVD, etc.).
brand.
TV
please do rate the solution positively.thanks
Mar 22, 2010 | Philips Televison & Video
How can i found the C7,2 on the canon F-502 calculator
Presume you are looking for the number of combinations of 7 things taken 2 at a time. If so key on my Casio F-720iis probably the same as your F-502. That is 7, shift, nCr, 2, =, should give you the solution.
Jun 11, 2009 | Canon F-502 Calculator
Canon F-502
I had the same problem and wrote to Canon for help. The reply was I could purchase an operation guide from Canon at US$10+ plus tax. My response to them was "I can easily buy a new F-502 at Staples at C$9.99, which shall come with a guide". Funny, isn't it?
Aug 09, 2008 | Canon F-502 Calculator
I have a Canon F-502 calculator, without guide, and I can't seem to figure out how to clear the memory. Should be simple but !!!!!
To clear the memory on a Canon F-502, press the X->M button next to the MR button. You will see the "M" letter disappear in the screen and your memory is now clear. Hope this helps!
Apr 14, 2008 | Canon F-502 Calculator
Canon F-502 Calculator Logo
44 people viewed this question
old marine
old marine
