Question about Braun 4729-649 Charger Sonic Complete
Sonic complete toothbrush - broken wires
Broke all four wires from the transformer to the PCB. How can I tell where to solder them back - 4 wires, 3 connection points.
Why does an electronic transformer not give any output?
Measure across the secondary of the transformer. If >20vac is present the board has the bug. Look for a fuse on it and visually inspect for a bad solder joint, if the board runs very warm solder joints can fatigue. If no voltage out of transformer you can buy a replacement using spec of 20volt secondary at 3 or 4 amps, since a 20 watt at 20 volt bulb consumes about 1 amp and there are 2 driven by the transformer.
Apr 28, 2014 | Exercise & Fitness
Identifying specs of blown transformer on PCB
I have the same problem, with the same transformer. Did you ever find the specs?
I was thinking of buying the Frigidaire board, connecting to line voltage and measure output voltage.
Jul 09, 2010 | Frigidaire FAC126P1 wall/window Air...
How to reconnect the copper cables in braun sonic
If you look closely, it doesn't much matter, because they are all twisted together when it is reassembled. Mine had two on the center and one on each end.
Aug 02, 2009 | Panasonic Sonic-1 ES 364 Electric Shaver
Viking 940 Sewing Machine will not run.
the transformer has broken solder connections between the pins for the plug and the transformer board. Brave? 4 phillips screw. Black box on bottom. remove ribllon cable. Transformer out. 2 screws black cover on transformer off. Theres the board with broken solder joints to the plug pins. The large plug they used on that model broke the solder joint easily. it shoudlnt be blowing fuses though unless he tried to fix it and put in wrong one.
Feb 09, 2009 | Husqvarna Viking 1
My Braun Oral-B Sonic Complete Toothbrush wont hold a charge
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Apr 21, 2008 | Computers & Internet
Vtech phone
May be inductive charging, like an electric toothbrush .The toothbrush and the base form a two-part transformer, with the base having one part of the transformer and the toothbrush having the other. When you slide the toothbrush onto the base, the complete transformer is created and charge can flow.
Mar 13, 2008 | Lands Phones
Leapster broken black wire.
Black is usually negative Or nuetral, so your assumption would be correct.
As for the cicuit Board end or PCB Side, i,d look to see where the Red from the battery goes on to the Motherboard. Observe the Size of the Solder Spot, and the Black Should be in Close Proximity to that. To be more sure, if you desolder, the spot.
And put a magnet on the desoldered/Solder. any remnants of metal strands, from the broken Wire, will magnetise.
As solder is mainly non-conductive. Tin/Lead.
If there are no visible signs, of the Black-Wire being adjacent to the Red. Look On The Opposing side of the Board.
The Additional Hint Here, Is to gauge by the length of the Wire.
Hope This Is A Fixya For You.
Mike @ Compurepair.
Feb 25, 2008 | LeapFrog Leapster Electronic Book:...
The USB connector broke!
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
Jan 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Pioneer P50A5-K goes to stand by mode
1) Pull chassis---remove power/convergence PCB==the one
with the large heatsink on it.
2) Remove solder from pins of four regulators on heatsink.
3)Clean board/pins w/ toothbrush & alcohol.
4)Re-solder, also solder both Stk's for prevent.
5)Re-assemble
Oct 10, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Braun 4729-649 Charger Sonic Complete Logo
90 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
