Question about Dell Office Equipment & Supplies
Dell m109s lens clean - Dell Office Equipment & Supplies
Can a Dell M109s use a brighter bulb, above he 50 lumen it comes with?
Not really I've tried but heat might be the issue! Let me know if you know there's a way
Apr 10, 2014 | Dell M109S DLP Projector
Tip
Fix Dell M109S Projector Fan Fault
Here's a video on how I fixed my Dell M109S fan fault. I also added a video on how to take it apart.
on Jun 26, 2015 | Dell M109S DLP Projector
Shadows on the images
have you tried another cable?
Dec 19, 2012 | Dell M109S DLP Projector
How do I clean the lens on a dell 1209S
please must note, and never clean it by cleaning wipes or paper, it will leave marks on the lens.
and nor to clean it by wipe or alcohol. it will easily break the protection film on the lens.
such the dust on the surface, you can blow it by blast.
and others, you can clean it by a good chammy
Mar 01, 2012 | Dell 1209S DLP Projector
The screen in green?
Sounds like a loose or broken vga cable. Push it in all the way. If it's still greenish try replacing the vga cable to the projector.
P.S. Is it just green in one spot or the whole image?
Mar 28, 2011 | Dell M109S DLP Projector
Is there a solution to fix Dell M109S DLP projector? Such as reset LED timer if any exist or something like this. Projector works more than 1 year but LED isn't work 10 000 hours of resource so i don't...
The first link is to the troubleshoot part of the user guide. Look for your symptoms in there and try the fix. The first video is one I made on how to take the projector apart. The second video is one I made showing how I fixed a fan failure.
http://support.dell.com/support/edocs/acc/M109S/en/ug/html/trouble.htm#wp1180421
Feb 10, 2011 | Dell M109S DLP Projector
The Menu bar was locked in Dell M109S DLP Projector how to unlock the menu bar,
All u need is to read user manual that says press the Menu key for 15 sec and Menu bar wil be unlocked.
Dec 26, 2010 | Dell M109S DLP Projector
Pink blue tint on display
Hello Adam, try replacing your signal cable. the signal cable has 3 color wires, 1 for red, 1 for blue, and 1 for green, the green wire is cut off, due to stress of twisting and pulling. find one on ebay. thats it.
Feb 08, 2010 | Dell M109S DLP Projector
DVD player
The lens is dirty . You need to clean the lens . You can clean the lens by using lens cleaner disk .
Jan 30, 2009 | Dell Dimension 3000 PC Desktop
32 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
