A back draft causing the kitchen to fill with fumes?
Came home to find the kitchen thick with smoke and the flame blown out the vent at the bottom is now black were the smoke must have come out, it is a white cooker,it happens when it is very windy, but we turn it up to keep the chimmey hot.HELP
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
You need to clean your chimney pronto.
Posted on Feb 15, 2014
Pilot flame flickers when burners on and drops out valve
You should either do a smoke test or use a candle to check for drafts to be sure that it is not a gas pressure issue.
Aug 13, 2014 | Kingsman FDV200 Free Standing Direct Vent...
Tip
Trouble shooting common gas water heater lighting problems
This covers just the basics on no burner flame or pilot outage issues on standard tank gas water heaters and does not pertain to tankless or instantaneous heaters. As always, safety first; if you do not understand what you are doing, do not attempt to make repairs on your own. This is just a guide to help you figure out what may be wrong.
1) Let's take care of the obvious things first. If you have a propane gas water heater, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. If it says you have plenty of gas, make sure the gauge is not sticking and bang the lid down. If the gauge drops down to 5% or less, order a gas delivery.
2) Remove the panel on the water heater to view the burner. Is the pilot still lit? Yes, then make sure the control knob is in the "ON" position. Also make sure the temp dial is not on "Vacation" setting or set at a very low temp setting. Typical dial settings are at medium "arrow" selection or "A" selection.
3) Is the pilot flame out? If you smell gas, do not attempt to light. Turn gas off at shut off valve on gasline to water heater and call your gas co. Otherwise, follow the manufacturer's lighting instructions on the water heater to relight. Pilot still won't light? Then you may have a dirty pilot orifice that needs cleaned. Or if you were out of gas and just got filled, you may have air in the lines and lighting the pilot will take longer than normal to light. It's best to have the gasman light this when he is there to fill your tank. It's also possible you have a control that is locked out or defective, which will require a serviceman to repair or replace the control.
Let's say you get the pilot flame lit. When you release the button, does it stay lit? No, then you might not have held the button down long enough, Try again. Still goes out? Is the pilot flame a strong blue color and actually making the thermocouple red hot? If so, and it won't stay lit, replace the thermocouple. Or is it a lazy yellow flame? If so, it may have burn't the tip off the thermocouple and it will need to be replaced. This condition is caused by a dirty pilot orifice, which will need to be cleaned with a broach to prevent it from ruining the new thermocouple you install.
4) Ok, let's say you relight the pilot and get the main burner to light as well, but later they both go out again. This only happens, of course, after the service tech has left. With it still off, get a flashlight and look inside the access panel in the area above the main burner? Do you see a lot of black soot build-up? If so, this make be causing your problem. Have your water heater serviced. If no soot, then check for blockage in your vent. Look for a bird nest or even a dead bird. Your vent cap is either going through your roof or through a wall to the outside. You'll need a ladder to check either. If it has bends and elbows, check those out for blockage too.
5) No blockage? Sometimes a vent is installed wrong (like under an eave) or you are getting a strong down draft. Make sure your vent cap is still attached on top of your vent too. Strong winds can blow out the pilot flame.
6) Here's another test you can do, if the pilot and burner shut down. Relight it as you did before and with the burner lit, reinstall the access panel. Now light a match at the draft diverter (standard water heaters have these on top which connect the water heater to the venting) Blow out the match near the edge of the draft diverter and watch where the smoke goes. (Shining a flashlight there also helps you see the smoke better) If it gets pulled into the draft diverter, it's working properly, pulling outside air in. If the smoke gets pushed out, you have a drafting problem. To make matters worse, you are also allowing carbon monoxide into the home. Have your water heater serviced immediately. I also recommend having a carbon monoxide detector located on every level in houses that have gas or oil appliances.
These are just a few ideas to help you figure out your common lighting issues. There are other issues that I did not cover, which may require a repairman. I hope you find these useful. If you still have concerns, please ask away! That's why we are here!
on May 16, 2010 | Water Heaters
Smell fumes like exhaust when furnace comes on
You really, really need to get your furnace checked by an HVAC (Heating, Ventilation and Air Conditioning) expert. Your furnace has a section where the fire heats tubes that air is blown across then out to your home to heat it. The air in your home and the air from the combustion process should never mix. If you smell exhaust, it's possible there is a breakdown in this part of the furnace and exhaust, which can include carbon monoxide, could be pulled into the air stream and be circulated in your home. Carbon monoxide can and will make you go to sleep and not wake up! Do not use the furnace until you get it checked.
Feb 08, 2013 | Goodman Furnace Draft Inducer Blower ...
I have a 30 gallen Rheem gas water heater. The water is coming out of the exhaust. Is there a way to fix this or do I just need to buy a new one?
I am uncertain from your description exactly where water is coming from.
I want you to protect yourself first.
Read following page to help identify source of leak:
http://waterheatertimer.org/Leaking-water-heater.html
If your vent pipe is spitting water back on top of water heater, then the problem is not the water heater. Problem could be poor venting.
Water heater is putting odorless CO gas into home, and will kill you. Give you headaches, make you feel sick until you go outside and get fresh air.
Call a plumber please if flue pipe is problem.
Here's how to check if flue pipe is drafting properly:
When water heater burner is off, light a match, blow match flame out, put match under vent hood on top of water heater.
Does smoke from match immediately draft up flue pipe?
If smoke does not draft up strong, then water heater is putting CO gas into home.
The vent on all gas appliances has to be working properly.
Look for missing top of vent pipe located on roof.
If cover is missing, a bird might built a nest on end of pipe, or leaves have fallen into pipe which is a fire hazard.
If flue pipe goes into chimney, you should call a plumber.
A plumber is cheaper than potential health problems with improper flue.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Rheem 30 Gallon FVR NATGAS Water Heater...
Pilot will light, burner lights stays on for a while probably till it reachers temp then pilot goes out, its a rheem gaurdian 40 gal
These are just a few ideas to help you figure out your common lighting issues. There are other issues that I did not cover, which may require a repairman. I hope you find these useful. If you still have concerns, please ask away! That's why we are here! Douglas
Sep 02, 2010 | Rheem Water Heaters
We have a rheem 30 gallon gas water heater / rn 1094a16941 -- the pilot light keeps going out - we have replaced the thermol couplier then it worked for a while and now it lights but won"t stay lit for...
This covers the basics on no burner flame or pilot outage issues on standard tank gas water heaters. As always, safety first; if you do not understand what you are doing, do not attempt to make repairs on your own. This is just a guide to help you figure out what may be wrong.
Aug 17, 2010 | Kitchen Ranges
Carbon monoxide into motorhome when using fridge
Check vent panels, on outside, as well as any roof vent for fridge to make sure no obstructions, that would stop the flow of fumes from flame, as well as check the flame on burner is nice and blue, and not orange, indicating rich mixture, which causes excessive fumes.
Apr 26, 2010 | Thetford Porta Potti
Getting fumes in home while heater is running
The pressure regulator can very well be the problem if you had the device three years with out a problem.
Is the devise vented? if so then maybe there is not enought draft to completely combust the fuel, if it is NOT vented then it very well could be the regulator sending more fuel to the devise that it is able to combust properly.
Jan 29, 2009 | Procom Heating & Cooling
When i increase the temperature control the oven soots excessive
Check your oven for flame color; what you are describing could be deadly. It is possible that you have an air vent clogged or blocked causing the flame to burn yellow indicating incomplete combustion and possible source of carbon monoxide. This is very dangerous and I would strongly recommend you purchase a carbon monoxide detector. We have one on the main floor and one in our basement.
A defective gas floor furnace in a home in a neighboring town 2 days ago put three children and two adults to sleep during the day and a 64 year-old man died of the fumes. The others are recovering but are all hospitalized. The family moved to Clay, WV from New Mexico only a week ago.
Dec 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
