Question about Tablets & eReaders
Tablet looped on android
Eurostar epad7+ ET754D-P13 looping on android at boot... 2 out of 3 tablets
  • 11800 Answers
SOURCE: Hi there I have a problem with my AT 100 Tablet.
This tablet, also called the Thrive, runs Android, loaded from its firmware. In your case it appears that the firmware has been corrupted and the only way to fix it is by reloading and upgrading it. Since the OS no longer starts the only way to reload the firmware is to access it directly , thru the boot loader. This is an extremely sensitive operation, no mistakes should be made or the unit will be permanently bricked.
If you have never done this before do not attempt to do it yourself. Better just take it to a dealer and it will have the correct software and expertise to do the job properly. It's an one hour operation so it shouldn't cost you more than $100.
Posted on Aug 07, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
jrolph621
  • 7 Answers
SOURCE: how do i unfreeze my android tablet after factory reset
let it sit at room temperature until it thaws out :-D
Posted on May 31, 2012
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Posted on Nov 23, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
My Samsung galaxy 2 tablet keeps restarting itself while i'm in the middle of something . why ? how can I fix this problem ?
Once the tablet has shut down, press and hold the Volume Up and Power buttons simultaneously until the Samsung logo appears. The Samsung Galaxy Tab will boot into ASR (Android System Recovery) mode. 3. Use the Volume rocker to highlight the 'wipe cache partition' option and the Power button to select it.15 Sep 2015
How to Fix the Samsung Galaxy Tab Reboot Loop - Appuals.com
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Samsung+galaxy+2+tablet+keeps+restarting
see if this helps you out.
Dec 17, 2016 | Samsung Tablets & eReaders
Can the battery be taken out of a Samsung Galaxy 3 tablet
To fix this, you have to disconnect the battery from the motherboard. That's right, you have to remove the back and pop off the battery connector. The only difficult part of this solution is removing the back of the device. I highly recommend using tools. I happen to have super-strength thumbnails, so I was able to pop the back off without the tools (I don't recommend this to anyone with mere mortal nails). To pry the back off, you insert the tool into the seam between the glass and the side, and carefully pop it out. There are a number of connectors, so this will take some time.
Jul 01, 2016 | Samsung Galaxy Tab 3 Lite SM-T110 8 GB...
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Jan 01, 2016 | Polaroid Tablets & eReaders
How do I get videos to loop on my nextbook ares 8 tablet?
some videos do not have loop options
it should be be with play settings
Nov 20, 2015 | Nextbook Premium 8 Se Android
Stuck in boot up loop after factory reset,upgrading android then stuck in boot loop
If you have it reflashed with the custom ROM try to reflash it to official.
Jun 21, 2015 | Tablets & eReaders
How Do I Reset an Idolian Studio 10 Tablet that is looping on the Android logo?
The robot dude meant it was loading up the system settings to the next screen so you can wipe off corrupted data that prevents the tablet from completing startup.usually an incomplete update.So
as follows ... Hold power button to switch off tablet....then hold power button and volume up together for at least ten seconds.let the robot appear and do nothing until the menu option comes up to ask you to factory restore.you will lose all your apps and data.if the robot comes on and gets stuck make sure the tablet is fully charged and repeat the two button hold as this may take several attempts.sometimes Chinese technology is unpredictable.
Jan 26, 2015 | Idolian 10.1" Android 4.1 Jelly Bean OS...
How do i do a factory reset on a 8gb A13 google tablet?
Boot loop caused by too many apps memory consumption or os bootblock corruption - press the reset button with a pin
If that doesnt work switch on and press the power and up volume
You will be in recovery mode
Select recover system then reboot
You also load a new os from an sdcard -cyanogenmod
If that doesnt wrok you will have to attach to your pc download and run the android dev kit and use the command line to reload
Aug 20, 2014 | Tablets & eReaders
My Kocaso Android Tablet 4GB it loads to the android logo n stays there is there a way to reset the tablet
Hi.
If you recently had a modification on your ROM, you may be experiencing a BOOT LOOP which is common to Android Tablets. A factory reset would be the best solution to that. Here's how to do it;
Turn-off your Tablet by long-pressing your power button. To be sure it's totally shutdown, wait for at least 30 seconds before proceeding to factory reset. If your tablet's battery can be removed, it would help if you detach the battery and put it back again before proceeding.
Resetting your Tablet to factory setting erases all the data in your tablet's memory, so you have to be ready to encode all contacts again and stuff like that.
Factory Reset Proper;
1. Press VOLUME UP and POWER button at the same time without releasing until the device boots to "Recovery Mode".
2. In Recovery Mode, scroll down by pressing VOLUME DOWN until you reach the option "Swipe Data/Factory Reset" or any equivalent to Factory Reset therein.
3. Follow through the succeeding menus until the device initiates the reset.
Note: If your Device has a HOME button (usually located at the Center-bottom of the LCD), the buttons to be pressed to enter into Recovery Mode are HOME and POWER at the same time. Release only after the device shows it boots in Recovery Mode.
I hope this helps you.
Apr 23, 2014 | Tablets & eReaders
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
Jun 12, 2013 | Dell Android 2.3 Touchscreen 7" Internet...
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Tablets & eReaders Logo
115 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
