Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung hln5065w will freeze in black and white after 10 mins. I removed the dmd board metal cover and placed a small fan(from Target) in front of the exposed board. It will now play for hours which tends to confirm my theory that my problem is heat related. However, after I turn it off, if I try to turn back on before it cools down, I get sound and no video. Any thoughts on this? Maybe a bigger inside fan?
  • 60 Answers
Most likely the DMD board or you could have a funky color wheel but I highly doubt it.
Posted on Jun 09, 2009
SOURCE:
I need the shematics to install A DMD chip in my Mitsubishi Model WD-C657
When you take off the back cover you are pretty much looking at the chip. Right in front of you in the middle of the light engine is a little fan.
Remove the fan and you will see a big metal heat sink / shield. remove the sheild and you will see a circuit board. in the middle of the board is the dmd chip.
Aug 19, 2012 | Mitsubishi Televison & Video
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
I have black spots on my samsung dlp tv
I had the same problem with my Samsung DLP tv a couple of weeks ago. I had to clean the lenses, mirrors and the DMD sensor to fix it, you must remove the rear cover to do this. If the mirrors and lenses were cleaned but the spots were still there, the final thing to do is to clean the sensor chip on the DMD board. It is located under the heat sink behind the small fan in the lower center of the rear of the TV. The DMD board will have to be removed to get to the back of the sensor. All you have to do is blow some dry canned air across it to remove the dust, do not wipe it with anything. The repair is somewhat complicated and you will probably have to realign the picture by adjusting the position of the DMD board when finished.
Jul 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Turns on but eventually freezes in black and white
is better if u replace the optical block cost less money , also it come with new lamp and color wheel and new ballast , all this parts go bad after couple years
May 06, 2009 | Televison & Video
Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Feb 12, 2009 | Samsung HLN5065W 50" Rear Projection...
HLN5065W
there are 3 leds on the front that blink the error code. which leds blink gives you the error. if its just the standby/temp red led blinking, it has overheated for some reason. there are a couple other fans you could clean but check your ventilation. many people put too close to the wall or close it up in a cabinet. it needs atleast 4" from the wall and someway to vent out hot air and get cool air in. a different model had the temp sensor cause this issue, it is the silver thing right atop the lamp. you will have to pull the whole back panel possibly, there are two wires that hook to it and two screws holding it to the engine (lamp housing). if you get lamp and temp leds blinking, reseat the lamp door. timer and temp leds is a fan error, all 3 leds is a lamp error (lamp, ballast, colorwheel, dmd)
Dec 05, 2008 | Samsung HLN5065W 50" Rear Projection...
Tv freezes white and black negative image
Yes the digital board is the culprit. I need the complete model number so I can get you the correct part number. On the right hand side of the TV is a sticker with the model/serial and sometimes a version number. Get me all those and I will look up the part number.
Mar 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
259 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
