Question about Panasonic TC-P50X5
Panasonic tv tc-p50x5 won't turn on
Will not power on
localwonder
  • 6784 Answers
SOURCE: Where to get LCD screen for panasonic TC-32LE60 TV ?
Hi there, the only close part you could get is the actual cabinet. the actual screen will have to be shipped by the manufacture itself. these screens are filled with a liquid that is dangerous and has to be installed in a OSHA approved shop.
Posted on Feb 18, 2009
  • 8457 Answers
SOURCE: I turned on power and red light is blinking but tv
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 06, 2010
  • 78 Answers
SOURCE: my TV just turned off and the power light flashes
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Posted on Feb 26, 2011
  • 1039 Answers
SOURCE: I have a 46" Panasonic
C board at bottom of screen in back. Resear the connectors that correspond to the stripes. besure to disconnect the the power supply from the sustain boards before doing this or flat cables will be burt by arc. If this does not help replace the corresponding c board. If this still does not fix it then plasma panel is bad.
Posted on Aug 31, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Posted on Aug 28, 2012
I have a panasonic tc-p50x5 that wont turn on anymore. What do i do?
The red light on front should be blinking count the number of times and check out what the code signifies and then you check out the board suggested.
Jun 23, 2017 | Panasonic Televison & Video
Panasonic plasma tv blinking red (7 times)
The PANASONIC TC-P50X5 Y SUSTAIN BOARD TNPA5593 would be blown. See the link below.
Feb 07, 2016 | Panasonic Televison & Video
My panasonic tc-p50x5 will not come on after power outage. whats wrong?
Being in the field of electronics I can not stress this enough....POWER SURGE PROTECTION...and I am not talking about a power strip with "surge protection"...they are useless. That being said you had a surge that most likely blew out your main power board. There is a fuse on that board and if you are lucky that popped and it is an easy fix. If not, you will have to remove the board, get the numbers on it and search out a replacement. There are plenty of places online to get them but I use Allied Electronics. One thing to check while you have the tv apart is to check all boards for visible burn marks or damage from the surge.
Feb 05, 2016 | Panasonic Televison & Video
Why won't my TV power on?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 29, 2015 | Panasonic TC-P50X5
My TV Won't Turn On
When you are convinced the mains cable is good, and in a socket with power, then you should try to switch it of an on with the power on switch on the TV. Not with the remote control. If that does not change anything I'm afraid there is something wrong. Cold be a fuse, but all other parts, like in the power supply or in all other circuit boards, could have a failure. It takes skill, measurement tools and time to diagnose what exact. It can't be done over the internet.
Feb 17, 2015 | Panasonic TC-P50X5
I have a 50" panasonic plasma tv. Model# TC-P50x5. I had unplugged it and went to plug it back in and the tv will not come back on. There is no red light on the tv or remote. Can someone help me please.
power supply module is known to go bad on flat TV's, if you change it make sure you buy the upgraded model, because same model could go bad soon again. but I would check power to wall outlet as first option. and power cord as second.
Dec 22, 2014 | Televison & Video
How do I go about testing my POWER SUPPLY BOARD (sos-p) for defects?
Visual of board may give clues like a puffet top or end of a cap. other parts may look like they have been hot.
Nov 07, 2014 | Televison & Video
Won't come on after power outage
hi is it totally dead if so it's possible the fuse inside could have blown, this will be on the power board, glass type, if it has and you replace it and blows again then there's a dead short on the power board or on main board hope it helps
regards
shaun
Dec 30, 2013 | Panasonic TC-P50X5
Panasonic TC-P50X5 Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
