Question about Tunturi C45 Elliptical Trainer
C3 model squeaking during use
Squeaking during use appears to be coming from the internal region of the flywheel area
When i turn on my car i hear squeaking sound
Belts? Mice? Hallucination? ALL DEPENDS ON WHERE THE "SQUEAKING" IS COMING FROM.
Open the hood. If the squeaking is coming from the area of the serpentine belt, it is probably time to replace your belt. Also, check all fluid levels.
If the squeaking is coming from a particular pulley (such as the air conditioning compressor or the power steering hydraulic pump), there may be a problem with whatever the pulley is attached to.
If the squeaking appears to be coming from outside of the car, you are scaring the mice or hallucinating.
Jul 17, 2014 | 2006 Honda Accord
Occassional squeaking from front driver-side tire
could be wheel bearing ,could be cv joint could possably be bushings in suspenion.
Aug 15, 2013 | Toyota Cars & Trucks
Squeaking is definitely coming from the Ramp area either at top or lower. Hard to tell when I'm on it, and it does not squeak without weight on it...Everything seems to be fine outside of the squeaking....
Tip it over - there was a version that had a problem with the frame cracking where the ramp attaches. There is a kit to fix this, if that is what you find.
Jan 03, 2011 | Precor EFX 546i Elliptical Version 4
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
I am experiencing a squeaking noise from infront near the fan belt area. when i accelerate,it gets louder. I discovered that the power steering pump is leaking ,so i topped up the reservoir and it stopped...
i have a similar problem. a squeaking noise, sounds when i start the engine, and when i stop the engine. at times it comes when the engine is running and idle, and it lasts some time like a high pitched whistle. Ive had several mechanics look at it, and it seem to be one of the smaller pulleys that the belts run around. in the 2002 model (petrol) of the crv the belts are not the cam belts, becuase this model has a cam chain (much more robust!). so they all said its nothing to worry about. you can try having your pulley replaced.
Jan 18, 2010 | 2002 Honda CR-V
Steering wheel squeaking
they do that sometimes...Usually if you take some silicone spray and squirt it all around the area where you can hear the squeak,it will go away.
Mar 20, 2009 | Chevrolet Malibu Cars & Trucks
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Oct 25, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Tunturi C45 Elliptical Trainer Logo
56 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
