Question about Krups XP Coffee Makers & Espresso Machines
Almost no water comes through during cleaning program on a Krups EA8240 Espresso Machine
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Posted on Oct 21, 2009
  • 39 Answers
SOURCE: I have a Krups xp2070 that sends hot water to the
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Posted on Dec 30, 2009
Testimonial: "Thanks! Very helpful. Now we can (probably) solve a problem that will bring espresso back into our lives!"
SOURCE: how to use krups espresso machine
The metal nozzle under the rubber frother is plugged up. You can remove it with a wrench (it is threaded). I now wash mine after every use since mine plugged so badly I had to use wire to unplug it. Milk does that.
Posted on Jan 11, 2010
Model EA8240 stays in cleaning mode and cannot complete the program.
Check for leaks into the base (chassis) of the machine, also observe if it is going excessively to the drip tray while attempting cleaning. Replacement of the distributor will often solve this problem. They are a difficult, troublesome machine.
Feb 21, 2014 | Krups Coffee Makers & Espresso Machines
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
Espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Krups XP 9000 - Check Collecting Tanks
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u need adobe to open it
Feb 26, 2009 | Krups Super Automatic XP 9000 Espresso...
2 problems: not enough hot water, and where the rubberized tube goes
It's my opinion that the tube goes in the boiler so that when the water boils, the steam will push the water up the tube and to the brew head. Without the tube, you will just get steam through the grounds.
Mar 10, 2008 | Krups Bravo Plus 872 Espresso Machine
Icky stuff
I would suggest to disassemble the machine and clean individual parts, chunky orange is rust, which is not normal in the coffee machine tubing.
Jan 30, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
15 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
