Question about Conair HC318XW 4P
Wont stay charged
Clippers will not stay charged
Blade won't snap back on
make sure the clipper is running when you try to snap the blade on.
Dec 08, 2015 | Wahl 8786451A Arco SE Pet Clipper
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
I have an Andis AGC 2 speed and I cannot figure out how to get the blade on and make it stay on when I turn on the clippers.
Ok you should be connecting the blade whilst the clipper is on this will ensure the blade engages with the clipper correctly, simply push the front edge of the blade into the clipper untill the latch has snapped into place.
Aug 19, 2011 | Andis AGC2 Hair Trimmer
My adjuster on my clippers wont stay still, everytime i cut on the clipper the adjuster on the side wiggles and moves to the top..how do i fix this
Take the upper blade off of the clipper, there will be four (4) screws which secure the adjustable part of the lever to the clipper. You can tighten these screws and that will control how much resistance you get when adjusting the lever.
Feb 21, 2011 | Andis 01690 Hair Trimmer
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
I have an oster destiny cordless clipper...I keep it on the charging unit--it sounds very weak like it is going to die, I haven't even used it today! It is a new clipper...am I charging it wrong?
This Type of clipper has a NiHM Battery with a capacity of 1 hour charge. with no memory side effects. You may just have a defective item. I would return it to the place you purchase it. if you have problem with this e-mail me at askmannyssharpening@yahoo.com I have contact with Oster But you need an invoice from the purchase.
Apr 09, 2010 | Health & Beauty
1690 trimmer
Please send your clipper to the Andis repair department at 1800 Renaissance Blvd Sturtevant, WI 53177. If this clipper is less than a year old repairs will be done at no charge with a copy of the receipt. If the clipper is more than a year old there is a $6.50 service fee and $5.00 shipping fee, there may or may not be a charge for parts depending on what actually needs to be replaced. If you would like to talk with a customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 22, 2007 | Andis 01690 Hair Trimmer
Conair HC318XW 4P Logo
23 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
