Question about Sanyo Split System Air Conditioner
Fan broken need replacement
Fan on inverter broken need replacment
Carrier ciac inverter condencer fan motor not working
If you end up replacing the board, replace the motor also. Board failure can be caused by the motor. You need a service tech
Jul 06, 2015 | Carrier Heating & Cooling
OH error in toshiba inverter VF S11
Follows are the part of the manual
Possible causes
• The cooling fan does not rotate.
• The ambient temperature is too high.
• The vent is blocked up.
• A heat generating device is installed close to the inverter.
• The thermistor in the unit is broken.
Remedies
Restart the operation by resetting the
inverter after it has cooled down enough.
• The fan requires replacement if it does
not rotate during operation.
• Secure sufficient space around the
inverter.
• Do not place any heat generating device
near the inverter..
May 03, 2014 | Toshiba Electronics - Others
E.pu error in keb f5 inverter. the part no. is 09.f5.a1d-3a4a, ver. 1.0, 1.5kw. when powering up the drive, it gives 560VDC. please recommend what the problem could be.
The E.pu error is a general power stage failure.
Typically means that the unit has a defective power stage that would need to be replaced.
If it is an old inverter(early 2000's) there is a possibility that it could be a cooling fan problem since at that time there was a three wire fan used. May be able to replace the fan (must obtain from KEB) but there may still be problems with power stage. If it is from early 2000's then you might be better off replacing the unit with new current version.
Mar 10, 2014 | Inverter KEB COMBIVERT F5
ERROR power unit
General error of the power stage in the inverter. Part# and ser# of inverter would help troubleshoot better.
Maybe a problem with cooling fan if it is an older inverter. Typically when the error E.PU appears, it is too late. Power stage maybe damaged and would need to be replaced.
Nov 26, 2013 | Inverter KEB COMBIVERT F5
Keb inverter f5 error e.pu
General powericon1.png stage failure.
Most likely will need to replace the power stage or inverter.
Oct 03, 2013 | Inverter KEB COMBIVERT F5
My acer screen is just blank i think it took a knock is there a quick fix
You may have cracked or broken the FL tube (backlight) or the inverter board has failed.
If the tube is broken, it needs to be replaced (or you can replace the whole LCD if you find one cheap).
If it's the inverter board, look for a microfuse on the inverter board (the one connected to the FL tube). These fuses will sometimes go for no reason. Check it for continuity with an ohm meter.
If the fuse is good, you may need to get the inverter board replaced.
To find out if you damaged the fl tube, you have to open up the LCD panel.
This is not a job for the faint of heart, and you have to be really careful not to damage anything.
They usually shatter when they break too, so be careful there.
You may just want to tap the backlight area to see if you hear rattling glass.
Check for loose or dislodged cables while you're in there.
Mar 22, 2011 | Acer Aspire Notebook
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
My vector power inverter needs to be reset
Inverters use high power transistors to create an A/C voltage from a D/C input. These transistors are the common point of failure when the units are not cooled properly or used beyond their rated capacity. (Actually, you should always buy an inverter that’s rating for continuous use is well below what your actual need is). What’s most likely happened is that these have shorted out and need to be replaced. Unfortunately, replacement parts alone will likely cost nearly what a new unit costs.
Sorry to be the bearer of bad news; but you basically have a nice paperweight with some pretty lights and fans on it.
Feb 03, 2009 | Vector VEC056 MAXX Power Inverter
Sanyo  Split System Air Conditioner Logo
16 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
