E91 electrolux The washer/dryer makes some alert noise during the drying phase, the the display becomes unresponsive and E91 appears from time to time.
futureloginn
  • 734 Answers
SOURCE: Machine came up with E91 and then powered down
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
  • 668 Answers
SOURCE: aeg electrolux lavamat 74820 e91 fault
  • It indicates that there is no communication between circuit boards.
  • Power off, drag machine out onto the floor, remove covers, disconnect circuit board connectors and clean with a toothbrush.
  • Clean off any corrosion or crud, refit and test. Closely inspect the entire wiring loom and circuit boards, looking particularly closely at areas where the wiring touches the machine frame. Your'e looking for any signs of wear or fraying, which would allow the bare wire to contact the frame.
  • Check all wires and connectors generally for internal breakages caused by movement of the wiring loom attached to the drum.
  • If you could not find any torn wires call service technician to repair the washing machine .
Hope this helps .
Shane
Posted on Dec 06, 2009
Testimonial: "thanks we need a repairman to do this thanks anyway"
Daniel S
  • 4323 Answers
SOURCE: E91 CODE-BEEPS ARE 3-4 SECONDS
Hi
E91 error means selector LEDs do not light up and you have to check the wiring harness between the control board & the interface board. If defective, correct wiring problem, if the harness is good and none of the LEDs light, replace the interface board. If this does not correct the problem, replace the control board. Note: If only one of the LEDs will not light, replace the interface board. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 17, 2011
richroth
  • 9472 Answers
SOURCE: E91````
E91 Communications error between main PCB and user
interface
Posted on Apr 26, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: e91
    Hello - Typically error code E91 on Frigidaire washer indicates a communication error with the user interface to main control board. A certified technician will need to check the wiring between both parts. Either part could be defective or unit may possibly have faulty wiring. Depending on the diagnostic either or will need replacing.
    Posted on Nov 05, 2012
    Electrolux washing machine wh1092 when turn on lights 1,4 and 8 flashes. Nothing happens
    If I understand correctly there is blinking LED-s from "Prewash","Rinse Hold" and "End of cycle". In binary code it is fault E91 what means communications error between main PCB and display board.
    So, could be: main electronic PCB, display board or wiring.
    Dado
    Dec 13, 2014 | Electrolux Washing Machines
    Electrolux EW1087 with error code e91
    Communications error between main PCB and display board.
    Possible causes: wiring, main electronic,display board.
    Dado
    Jul 26, 2014 | Electrolux Washing Machines
    Frigidaire affinity front load washer, my power went out and came back on, now the washer keeps beeping 3 beeps about every 30 seconds. Error code E91 will flash up when I push any button
    Hi bsful1 - Typically, E91 indicates that the main control board has gone bad or is not communicating correctly. Before replacing this part, I would first recommend resetting power to the unit for about ten minutes. If the error code still displays, it is advisable to contact an appliance repair tech to accurately diagnose and make the appropriate repairs.
    Apr 11, 2013 | Frigidaire GLTF2940ES Front Load Washer
    Error Code E91
    E91 is for the control board failure and needs to be replaced. Here is the part to order. To replace the board remove the top of the unit.
    Dec 05, 2012 | Frigidaire ATF6000ES Front Load Washer
    E91
    Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Atf6000es error code E91
    Hi Angelia,
    E91 means that there is a communication problem with the user interface to main control board. You will need a certified professional to check the wiring between the main control board and the user interface board to determine which part has to be replace.
    Sep 12, 2012 | Frigidaire ATF6000ES Front Load Washer
    E91````
    interface
    Apr 25, 2012 | Electrolux Washing Machines
    E91:E94
    e91 is perticular flesh problum please go to your nearst sony service centre & fix this
    Apr 26, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
    Feb 19, 2008 | AEG Lavamat 72640 Front Load Washer
    Error codes
    Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
    May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
    Washing Machines Logo
    12 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
